How do I insert staples into a rapid supreme 17 stapler as it is in pieces?
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
sbg_ofp
  • 10 Answers
SOURCE: Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Posted on Nov 05, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
How do I prevent Rapid 5080e stapler from jamming
Make sure that the tray for the staples is clean and LIGHTLY oiled, Staples are held together with glue. IT could also be an issue with the wear on the staple head driver. If you use it a lot, the unit might be worn to the point that it is out of spec.
Aug 28, 2015 | Rapid 5080E HEAVY-DUTY FLAT CLINCH...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
I need to put in new staples. How do I do it?
This stapler does not swing open like a paper stapler. It has a little square metal piece at its heel (about the size of a postage stamp). Press in lightly on this metal piece as you move it up or down just a bit, to unhook it. Then pull out the piston and spring assembly, insert staples in the hole and replace the piston. You must use T50 staples (of various lengths). T35 and others will not fit. Good luck, Al K
Sep 01, 2010 | Arrow T50P ARROW STAPLE GUN
How do I reload a Rapid S1 Supreme stapler?
  • Hold the gun in your right hand
  • The clip shield is spring loaded, when it released it will move toward base.
  • Near the base of the hand grip on the left side there is a metallic clip, free it with your left hand.
  • When it opens, check for obstructions, single staples, etc.
  • If it's been a busy day, add a couple drops of light oil to the moving parts.
  • Insert a clip of staples.
  • Slide the guard home, The clip will snap into place when it registers.
Then your good to go...
Best regards
Mike
May 20, 2010 | Stanley Pneu Roof Stapler
I have a very old Bostitch staple gun Model T5. It has run out of staples, but I cannot figure out how to put new staples in it.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Dec 23, 2009 | Stanley Tools & Hardware - Others
When pressing the trigger to fire a staple, all I get is an air leak from the area of the trigger.
They all leak a little on firing. Is it a big blast of air or just a hiss? All guns have a 'safety' device that keeps them from firing unless you follow a set pattern. You must push the gun down where you intend to put the staple which releases the safety before you pulll the trigger. You must then release the trigger move the stapler off the piece push it back down again before you can fire another staple. You can get (free) frrom the manufacture a rapid fire shoe and trigger that allows you to hold down the trigger and bounce the stapler along your work shooting merrily away.
May 08, 2009 | Air Tools & Compressors
76 people viewed this question
k24674
