We have a stain on our wood floor from rotten potatoes. It has discolored the ash wood floor.
5 Suggested Answers
SOURCE: wood stain in carpet!!!!!!!
Try white, not gel shaving cream. Apply it with your finger by rubbing it in, let it sit for about ten minutes and then wipe up with a damp rag. This works on many stains and will not ruin your carpet.
Posted on Feb 04, 2012
caroldon
  • 17130 Answers
SOURCE: why does my washing mashine smell of potatoes
Tips to clean your washing machine: click on : cleaning machine
Posted on Jun 26, 2012
headstrong56
  • 493 Answers
SOURCE: white stains in dark pine wood
Sand it down and refinish it
Posted on Jul 30, 2012
  • 29 Answers
SOURCE: why when i do a casrole or potatoe ash the meat is always dry
try a pan of water in grill next to it for moisture
Posted on Nov 24, 2012
When steaming wood floors leaves floors wet
Kathy if you are talking about hardwood floors you should NOT use any kind of steamer ever on them .
The wood is eighter oak or yellow pine most common however cherry and moghagany on high end houses and used .
But it is all what is called tung and grove and is finished on the top olny with an interior finish that dosn't work well with moisture let alone forceing steam under it it will soak into the bottom of the wood and then the wood will start to cup become uneven on open up .
The best thing you can do if you have this problem let it dry out might take some time weeks or more .
Then rent a floor sander sand it stain it and put at least 3 coats of a polyurthane over it if you use water base poly you will need more coats.
May 08, 2015 | Vacuums
My stain is darker on one side of floor...used minwax polyshade and it looks like two totally different colors.
Did you mix the stain up before you used it? Is it possible that there are two different woods on the floor? Is the difference delineated from one board to another or is the difference in shade blotchy? You can try to mix the stain you have with a lihjter stain, but that is a hit-or -miss propostion.
May 05, 2014 | Minwax Hpt Interior Semigloss Polyurethane
How do i finish a doorway threshold going from hardwood to linoleum, there is a height difference, the hardwood is lower.
You need a reducer strip. Find a local hardwood flooring supplier and tell them the height difference between the two floors and the length of the opening. Once you have the right reducer find a wood stain that matches your floor. Next stain the reducer and finish with either a high gloss or matt finish polyurethane coating available in a spray can. Once the piece is finished your ready to install it. If the subfloor is wood then you can nail it down and putty the holes. If your subfloor is concrete then you will need to glue it to the floor with some liquid nails. Apply the glue to the bottom of the reducer put into place and weigh it down for 24 hrs.
May 29, 2013 | Building Materials
How to stain a solid wood floor
They have paint on it.If have it you have to remove old paint.Some place have machine to remove old paint you can rent.Then put new stain.
Apr 10, 2013 | Sub-Zero 611 / O Bottom Freezer...
What is laminated Floor?
Basically, laminating is the result of a direct pressure process that fuses four layers into one durable surface. The laminating technique originally came from Europe and spread worldwide in the last decade.
Jan 10, 2013 | Building Materials
How do you get rid of white ***** residue from vinyl floors?
Vinyl is resilient. You can use a mixture of white vinegar and warm water to remove the stain.
Nov 20, 2017 | Building Materials
Loosing wood colour in exterior deck flooring, floor unused for6m
When I recoat my outside wooden seating I use Danish Oil and if the colour has faded I add a small amount of stain of a suitable colour. You could try it with the linseed oil but the Danish oil dries to a hard coating and will build up if several coats are used, allow time to dry between coats.
Regards
Alan Hood
ami-man
Apr 19, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
