Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
The engine runs but the battery won't charge.
Battery won't charge
Posted on Sep 28, 2010
I have an 03 Chev malibu. I just put a new battery in it. She won't start without a boost.runs fine afterwards.if I let her sit for a bit I will need a boost again..please help
New battery could be faulty or alternator not working.
If nothing happens when you turn the key,to check battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested.If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
the link below explains a complete diagnosis,
press the helpful button
Engine Won Crank or Start
Jan 19, 2016 | Cars & Trucks
Battery won't stay charged
The engine will have a generator under the flywheel, this should charge the battery when the engine is running, you can use a negative shunt on the battary terminal to check what if any power is going to the battery from the engine.
Apr 02, 2013 | Garden
The battery won't stay charged
Hi it is possible that you Alternator is faulty,if you have access to a VoltMeter ,check the battery voltage in the morning before you try to start it you should have around 12.7 volts for a charged battery if not fully charge your battery again and check the voltage with your car running you should have around 14 volts with the engine reving at 1500 revs.ifyou get around 12 volts then your lights are taking more power from the battery than the Alternator can replace.You could also get your local garage to Drop Test your battery to see if any of the Cells are faulty
Jan 11, 2013 | 1987 Volvo 740
I have a 1994 f-150 pick up got a new battery & when i put the heat on it discharges & now truck won't.
You mean with the engine running? If the engine is running, the heater fan should be getting power from the alternator, not the battery. Does your battery light go off after engine is running? Or does the voltage gauge show normal charging when running?
If you can start the truck, have your charging system checked out. If it won't start now, have the battery charged up and try again. Then have the charging system checked. If it is good, your heater fan may have a short and drawing too much current, But a heater fan will run the battery down pretty quick, if the engine is not running.
Jan 06, 2013 | Cars & Trucks
1992 Mazda mpv . Won't hold charge . Engine won't
The first thing to do is have the battery tested, just because you charged it doesn't mean it will stay charged if the cells are sulfated up or shorted.
Oct 02, 2012 | Cars & Trucks
Have New battery and Alternator, battery still won't stay charged.
Since you are having a new battery and alternator the charging circuit of the electronic charging unit is a possible suspect.
All what is required is to check the charging voltage when the engine is started, if there is no increment of voltage when the engine runs the alternator then the connection from the alternator must be checked. Check the output from alternator, check the relay box which contains the charging unit. It can be a failure of the rectification or the stabilising circuit, the unit must be replaced.
Sep 21, 2011 | 1993 Buick Park Avenue
My 2005 durango want cran over
What happens when you attempt to start the engine? If nothing happens when you turn the key,you need to check the battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested. If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
Jun 25, 2011 | 2005 Dodge Durango
Dear sirs, I have a 2000 Ford Explorer which won't start. All light in the dashboard turn on but the engine won't crank. We've tried to crank the engine direct from the battery and it cranked....
yea got get you more troubles
just check the alternator is charging well and no battery light on dashboard it indicate the bad alternator
monitor your battery if it got old and cannot hold the charge any more
you said when you used another one your car turned on
Jun 06, 2011 | 2000 Ford Explorer
Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Jun 25, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Car won,t charge the battery the alt is good i had it checked
depending on the year model of your car the voltage regulator is intergrated in the pcm
Apr 23, 2009 | Ford Contour Cars & Trucks
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
