Hello good day, I have a samsung LN S32510 LCD and for some reason it just stop powering on. I was getting a red light but I'm not getting anything now. Any help would be appreciated. Thank you Jamar
SOURCE: Samsung LN-T4042H 40" LCD
This may not really be a solution to your problem, but here it goes. If you are not sitting a particular distance from your tv you will experience slight pixelation. I have this tv myself and I think it looks great. Now when I am sitting up close on a station that is broadcasting in 720p(which is pretty much every HD station) It looks only pretty good...I sit back and it is fantastic. The good rule of thumb is take the number or inches your TV is in yours and my case 40, divide by 10 and then multiply by 2...and that is the number of feet you should be for optimal viewing distance. So 8 feet, you would be surprised to see how sitting this magic number away makes a difference.
Posted on Feb 12, 2008
  • 98 Answers
SOURCE: TV not switching on
Can you hear the sound of turning on?
I think that you need to replace the main board.
Posted on Feb 09, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
  • 78 Answers
SOURCE: Samsung LN-T5265 LCD tv will not power up.
Try a different power point and a different power lead. We hire out Samsung LCD's and occasionally find that it's the lead or something else in your power circuit is causing the problem. Otherwise the other issue we've run into is a faulty power supply in the TV itself in which case hopefully it's still under warranty (I believe it has 3 years)
Posted on Sep 15, 2009
SOURCE: Samsung LN-T4032H
This is the capicator $1.50. You have to take off the back, sauter off the capicator (you'll see it because it is poking out) and sauter on the new one. I found the fix on this web-site.
Posted on Oct 04, 2009
Monitor will not turn on. i've tried the remote with no luck. all i get is beeping and a flashing red power light.
The Power supply board of the Television is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Hope this will help out
May 06, 2011 | Samsung LN-T1953H 19 in. LCD HDTV
My Samsung LN S3238D won't turn on. It suddenly went out one day for no reason. I've checked the capacitors in the back and they are fine. No clue what it could be and I don't want to pay someone hundreds...
hello, Normally the power supply board has to be replaced. It is cheap if you do it yourself since you only pay for the board. These sites normally sell them, shopjimmy.com or discount-merchant.com
hope this helps
Aug 26, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
Hi I bought a samsung lcd tv about 1 month ago and it will no longer turn on. It still flickers the red light but nothing happens. Any solutions? Thanks
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Take care...
Aug 10, 2010 | Samsung LN-S4051D 40 in. LCD Television
Samsung LCD TV will not turn on or off. Red light
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 25, 2010 | Samsung LN-T4065F Television
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T4032H
Oct 01, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
My Samsung LCD TV will not turn on, it just clicks
A Replacement Power Supply.
Parts: £80 - £110 depending on the model.
Labour: £40 (ish) little bit more with a 90 day warranty etc.
Type your model number into www.chsinteractive.co.uk for the price on a PSU.
Good Luck.
Sep 07, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung LNT4665FX LCD-Clicks before coming on
Bad power relay get it fixed before you have more issues the psu cost around $25 bucks on ebay good luck!
Aug 15, 2009 | Samsung LN-T3253H 32 in. LCD Television
We had a power outage and the next day all I could get on my TV was the blinking power light. Can you hellp me? I have a Samsung 42" LCD Flat Panel HDTV Model No. LN T4042N edit
Hi, the power surge has destroyed the power supply board that is located inside your lcd cabinet. this board works in conjunction with an inverter board that regulates the raw ac current that is used for many different functions in your set. Normally, this type of damage will be isolated within the power supply but, it could have spread to the main control board as well, depending on how well the surge protector preformed during the surge.
The good news is that, this is a repairable situation. you can replace the power supply circuit board and inverter board as well. these replacements will fix this issue.
please rate and god bless:)
Apr 18, 2009 | Televison & Video
Samsung LN-S3251D
We have the same problem we have had ours for 2 months, went to turn it off the and the tv froze, could not turn it off or change channel. We had to turn it off at the power point, now it will not turn on at all. The red light flashes but no picture.
Jul 05, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
