Question about Linksys PAP2T
I have a pap2 device with linksys and cisco systems written over it... constant red light with green light in the ethernet.. and no lights in phone 1 and phone 2 so cant access the IP by dialing **** please help fast i dont know whats happening as it was working fine in the morning.... please help fast
How can i reset linksys pap2 device withbreak password
Posted on Jan 04, 2011
I have a problem with connecting modem and router. The ethernet light turning off after 3-5 sec after the router is turning on. Modem don't see router, like it's not connected. When I connecting modem and...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Best of Luck
Feb 12, 2011 | Linksys EtherFast Cable Modem with USB and...
I have forgotten all details of password to change my entry into Wireless-Gv Broadband router WRT540.I need its passport to establish a Wi-Fi connection for my Amazon Kindle.William D. Little
Default backdoor passwords
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
WAP11 MULTI n/a (none)
LINKSYS DSL TELNET n/a admin
LINKSYS ETHERFAST CABLE/DSL ROUTER MULTI Administrator admin
LINKSYS LINKSYS ROUTER DSL/CABLE HTTP (none) admin
LINKSYS BEFW11S4 Rev. 1 HTTP admin (none)
LINKSYS BEFSR41 Rev. 2 HTTP (none) admin
LINKSYS WRT54G HTTP admin admin
LINKSYS WAG54G HTTP admin admin
LINKSYS LINKSYS DSL n/a admin
LINKSYS WAP54G Rev. 2.0 HTTP (none) admin
LINKSYS WRT54G Rev. ALL REVISIONS HTTP (none) admin
LINKSYS MODEL WRT54GC COMPACT WIRELESS-G BROADBAND ROUTER MULTI (none) admin
LINKSYS AG 241 - ADSL2 GATEWAY WITH 4-PORT SWITCH MULTI admin admin
LINKSYS COMCAST Rev. COMCAST-SUPPLIED HTTP comcast 1234
LINKSYS WAG54GS MULTI admin admin
LINKSYS AP 1120 MULTI n/a (none)
LINKSYS PAP2 / PAP2V2 (VONAGE) HTTP admin admin
LINKSYS RT31P2 (VONAGE) HTTP admin admin
LINKSYS RTP300 (VONAGE) HTTP admin admin
LINKSYS WRT54GP2 (VONAGE) HTTP admin admin
LINKSYS WRTP54G (VONAGE) HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP admin admin
LINKSYS/ CISCO RTP300 W/2 PHONE PORTS Rev. 1.0 HTTP user tivonpw
also, holding the reset button for about 30 seconds will clear the password usually.
hope it helps.
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Oct 28, 2010 | Linksys Wireless-G Broadband Router
Have linksys broadband router model # rtp300, formally used to receive Vonage service. Can this devise be used to connect a second computer in my home?
Yes.
This is a wired router.
you can connect second computer to the router.
You will need to connect the cable to the router's ethernet port and computer.
Click Here to know more about router and network
Feb 04, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linsys voip internet phone adepter PAP2T ip address
pulg phone pin in pap2 device phone1 pin then give internet connection to pap2 then dial from the phone *110# then u can here ip from pap2
Nov 11, 2009 | Linksys Computers & Internet
Lost my password
Hi Friend,
The Linksys PAP2 Device is a user friendly device.
The solutions is u must reset the router to the factory settings i.e., to default setting
u will be having a reset button at the back side of the router ,hold it for 5 to 10 sec and release the router will be getting on automatically then u can configure again from initial.
Regards,
Ayyasam
Apr 27, 2009 | Linksys Cisco SPA9000 VoIP Gateway - 1 x...
Delay ring tone
after dial phone no. just dial # for quick ring tone and for good sound quality just choose preffered code g723 and save it. Hope you will get solution
Mar 10, 2008 | Linksys PAP2 Network Management Device
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys PAP2T Logo
299 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
