Question about Frigidaire Dryers
My frididare electric dryer stopped heating. model # is gler341a. I need to know the best way to get to the thermostat.
  • Frigidaire Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 27, 2010
Dryer is running WAY too hot.
Hi givn2fly
Your high temp thermostat is faulty, replace it.
Bud
Apr 04, 2013 | Frigidaire GLER341A Electric Dryer
My dryer is not getting hot to dry clothes
That sounds like the heating element has become defective.
You can find the parts HERE if the model is GLER341AS0
You can find the parts HERE if the model is GLER341AS1
Though, I highly recommend you either take it and consult the location you purchased at. Or try calling Sears or Best Buy to see if they can coordinate a repair for you.
hope that helps.
Mar 04, 2011 | Frigidaire GLER341A Electric Dryer
Daryer is not heating
The heating circuit of the electric dryer consist of the following parts. The timer, the heating element, the hi-limit thermostat, the safety thermostat, the operating thermostat, the temperature switch and the motor centrifugal switch.
If any of these parts fail, the dryer will not heat. Now, most people when the dryer stops heating, replace the heating element or the timer with out checking to make sure that those parts are bad. Rule number one is, don't assume that the part is bad with out checking it with a multimeter.
The first and most important thing you need to do, is to disconnect the dryer from the wall outlet before doing any kind of work on it. Most parts will need to be checked for continuity and the dryer must be disconnected from the wall outlet.
Most of the times the part causing the problem is behind the dryer and you can gain access by removing the back panel.
Remove the back panel on the dryer. Disconnect one of the heating element wires and take a reading between the two terminals on the heating element. The reading should be between 10 and 50 ohms. If the heating element is good, check the hi-limit thermostat by removing one of the wires and checking for continuity. Continuity means, that electricity could pass through the part that you are checking.
The hi-limit usually blows when there is an obstruction on the exhaust hose, so make sure that the exhaust hose is not obstructed when replacing the hi-limit kit.
If the hi-limit thermostat and the heating element are ok, check the operating thermostat. The operating thermostat is in charge of maintaining the temperature inside of the drum at about 150 degrees. You will need to check from the two terminals with the red wires attached on it.
Those where the parts that fail more often in the Whirlpool electric dryer. The timer, the motor centrifugal switch, the temperature switch are a little harder to check because there are may different one. You will need to use your wiring schematic to see how to check them.
Aug 17, 2010 | Frigidaire GLER341A Electric Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer heats but only at low temperature. takes several cycles to get cloth dry
Usually the relay (in the internal thermostat) is bad or if their is a second heating element, it can be bad. Also, the controller/timer can cause the problem but usually not.
Good Luck!
Oct 07, 2009 | Frigidaire GLER341A Electric Dryer
Need to get to the heating element, how do you do that?
how do i get to the heating element on my frigidaire heavy duty dryer
Oct 03, 2009 | Frigidaire GLER341A Electric Dryer
Heating element to hot.
Replace the hi limit thermostat. it has failed.
Jun 25, 2009 | Frigidaire GLER341A Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
My dryer heats up and then stops heating. What do i do
Have you checked the venting and lint trap for clogging, it sounds as if it is not getting adiquite air flow, in turn tripping the hi limit switch
Feb 09, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
Dryers Logo
27 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
