Question about Sport & Outdoor - Others
Lights quit working on 2007 Honda Rubicon 500 Quad has low miles and the fuses are good..is there anything else besides wiring that I can check for?? Thanks
johnny_20
  • 161 Answers
SOURCE: honda civic wont start
You might have to change the spark plugs or at least have them cleaned.
Posted on Jul 12, 2008
  • 178 Answers
SOURCE: low beams
hello i no you said you checked your fuse box go under your hood drivers side near your strut tower their problay is a second fuse box its black some times fuses is on the cover you have to unlock the side of cover lift off on inside of cover will list what is what sometimes left and right headlamps are seperate fuses goodluck
Posted on Sep 14, 2008
  • 10 Answers
SOURCE: 1999 honda foreman rubicon 500 wont charge
if it wont hold or take a charge it might be the battery terminals or the the alternator. check out both.
Posted on Oct 15, 2008
BCally1
  • 133 Answers
SOURCE: Right High Beam Inop, all other lights work properly
might want to have the TIPM vehicle configuration reset. if that doesnt do it it probably needs a TIPM. these things seem to be pretty touchy
Posted on Jan 22, 2009
  • 14036 Answers
SOURCE: low beam and running lights will not come on
check relay and the fuse.
Posted on May 16, 2009
All my lights quit working on my 2007 Honda Rubicon, what do I do if the fuse is good?
check ground wire s make sure there grounded properly clean surfs if not bulb !
Oct 23, 2016 | Honda 2007 FourTrax Foreman Rubicon
Will not shift gears & light blinking 5 times
500 rubicon trans problem. - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../honda/117842-500-rubicon-trans-problem.html
Sep 17, 2003 - It has low gear and reverse only will not up shift in any mode. ... Had the same problem with mine, went to my local honda shop and he had ... My lightswould flash and the trans. wouldn't do anything, had to shut ... Code 5 - Angle Sensor System (Motor lock i.e., angle sensor, wiring, .... All times are GMT -5. Honda Electric Shift (ES) Problem Solved
Mar 25, 2012
My Recon 250 ES Shifter Problems
Jun 28, 2010
HONDA 450 ES FOREMAN SHIFTING PROBLEMS - Page 4
Nov 20, 2005
recon 250 es shifting problem
Oct 10, 2004
More results from atvconnection.com
check engine light blink 5 times rsx ATVs Questions ... - Fixya
www.fixya.com > Forum > Tags > check engine light blink 5 times rsx
Question about 2012 Big Red MUV ... Check engine light blinking on Honda big red muv Check engine light slowly blinks ... My 2014 honda foreman 500 es 4x4 neutrallight blinks 4 long times and 2 short times and will not shift into gear.
Honda blink 3 times ATVs Questions & Answers - Fixya
Feb 08, 2016 | Honda 2012 Big Red MUV
2007 500 Honda Rubicon. Why doesn't 4 wheel drive work?
When you do this, your just checking the differentials, front and back. The transfer case needs checked. FWD and AWD are different. On AWD, the rear differential is what is turned on and off. Both have to be diagnosed with a scanner. Doing it yourself, You can replace high dollar items and it was only a broken wire.
May 20, 2015 | ATVs
2001 honda rubicon 500 oil in air box
how many miles covered, could be blocked breather, also could have been overfilled some time. clean it out, do 500 miles and recheck
Oct 08, 2014 | Motorcycles
Honda matic 500 trx rubicon 2002 front end does not pull no noise
Repeat the process with a manual. Sounds like shaft not engaged.
Jun 01, 2014 | Honda 2013 FourTrax Foreman Rubicon
Honda vt750 brake light not working have replaced bulb and checked fuses which seem to be ok. Won't work on foot pedal or hand brake, What should I check next?
the wires typicaly are ran under your rear fender, this leads to the possibilty of tire hitting wire and breaking it. friend had a bigdog and everytime his wife rode '*****' (no she aint a hog) around 5 miles brake light would quit.
Jul 25, 2011 | 2007 Honda VT 750 Shadow
Flasher module 2007 Rubicon do I need to replace when towing?
Quite often the answer is yes. The extra power draw from added lights, will usually require HD flasher.
Apr 11, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Ford f-150 brake light and blinker problems (from towing)
Check the fuse box located in the cab down by the drivers left knee. check all the fuses there, also consult your manual and check the fuse for the brake/tail lights. This sounds like a fuse problem more than anything. Thanks for using fixya! Good luck!
Sincerely,
JC
Dec 29, 2008 | 2006 Ford F-150
Sport & Outdoor - Others Logo
154 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
