Question about Lexmark Pro X125 All-In-One InkJet Printer
Lexmarkx125 printer menu says add cartridges. I remove and replace cartridges, and the message stays the same . I am using refilled used cartridges .Will not print. the add cartridges message stays on.
  • henry_lewis0 Sep 14, 2008
    The same thing happens to me
    Problem Solver:
  • 14 Answers
Same issue with me, using a genuine cartridge... cartridge sensor is probably stuck or hung... i know of possibilities to "trick" the sensors on refilled cartridges... i just don't have the documentation for that anymore... it came with my ink refill package
Posted on Oct 22, 2008
  • orangemek Oct 23, 2008
    I just spoke with Lexmark tech support. On the phone - no luck, printer no longer covered for phone support, on live chat, was told it was a defective printer and that they can't do anything. also sent an email to which I'm expecting the same answers. I'm not going to change the unit.... it does everything i need, specially since i don't use color... just a drag coz i dropped ~70$ for the black and color cart's, when i could've bought 2 black ones....
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
I have a HP PHOTOSMART 2610 all in one printer and have developed a printing problem. This printer has been working as it should up until just recently. I have been using the Walgreen's photo service...
Because is refill.When refilled a small gap is detached to make the refilling and it no longer recognize as the brand it use.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | HP Photosmart 2610 All-In-One InkJet...
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Thank You for using Fixya.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
7310 ask to control/check bla/wh cartridge. Replaced with new one and keeps on asking to replace. How to resolve?
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Errror
Hi there
Instructions
Things You'll Need:
Adhesive tape
Step 1
Step 2
Step 3
Step 4
Next Steps
Step 1
Step 2
Step 3
Step 4
Mar 05, 2010 | HP PSC 2355 All-In-One InkJet Printer
I have a brother 2140 printer, it ran out of toner and i refilled toner starter cartridge , and error message comes back to clean the corona , i replaced ther cartridge with a new tn-360 cartridge, but...
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Dec 31, 2009 | Brother HL-2040 Laser Printer
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Refilled Cartridge
How can I Reset Memory For Lexmark X4550
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark Pro X125 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
