Question about Hoover Washing Machines
How to replace gearbox, new bearings on a Hoover Boss 800
    Brigadier General:
  • 3,917 Answers
For replacing bearings first take the power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the back plate. Refitting is a reversal of the above process.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 28, 2010
700LC will not spin
The older Hoover had a problem with the clutch drive seizing. Sometimes it was caused by the aluminium housing on the gearbox breaking or cracking. When this happens, the clutch pawl doesn't release the clutch gear properly. The clutch stays in the locked position and then it wont allow the tub to spin. Its not often the top bearing fails. A common sign of gearbox / clutch failure is a brown oily stain spread all over the inside of the cabinet in line with the bottom of the gearbox. This means that the gearbox has slowly filled with water through a failed gearbox seal and when it gets to this stage, its not an economical repair. Time for a new washer unfortunately.
Feb 22, 2014 | Hoover Washing Machines
We've got quite an old type of washing machine: a Hoover A2580 - S: It had been running well from 1991 to last summer, when it slowed down, so the condensator had to be replaced. It worked well for a year,...
It sounds like your diagnosis is correct. A failed bearing will cause the symptoms you describe. The bearing can be replaced but is a pretty big job. With the washing machine being almost 10 years old I would recommend looking around for a new one. The bearing replacement will usually run over 1/2 the cost of a new machine.
Aug 22, 2010 | Hoover Washing Machines
THE GEARBOX SELECTOR SPRING IS BROKEN AND THE GEAR SHIFT LEVER WILL NOT SELF CENTER, ALL THE LINKAGES ARE FREE AND WELL OILED ITS A 2001 BOSS HOSS 2 SPEED OUTO
Hi, Daveice_2000 you need to replace the broken spring for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
THE GEARBOX SELECTOR SPRING IS BROKEN AND THE GEAR SHIFT LEVER WILL NOT...
http://fullmanuals.com/brand/boss-hoss
https://www.bosshoss.com/parts.asp Boss Hoss Cycles Contact U Boss Hass Motorcycle Specifications
Jul 28, 2010 | 2000 Boss Hoss BHC 190-355-500 Hp
I have a Porter Cable 345 6" saw "3" series. Do I need to oil this baby?
unless it has a gearbox with a plug, no. the bearing are sealed. where the saw breaks down the middle, the metal part from the plastic part, there is grease in that gear compartment.
Jul 11, 2010 | Porter Cable 345 6" Circular Saw Saw Boss
Type of lubricant required for a hoover model 800 RLA gearbox
Lithium grease.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 04, 2010 | Washing Machines
How to fix noisy throw out bearing
Remove gearbox Fit new bearing Check clutch while you have gearbox out Renew if necessary Replace gearbox Easy! Have fun
Oct 22, 2009 | Cars & Trucks
Replacing bearings in the rear axel- 99 boss hoss- replaced rearaxel with newer housing with grease zert- is ther a sealed bearing for this!
Hi, Davef927 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Replacing bearings in the rear axel 99 boss hoss replaced rearaxel with...
http://www.autopartswarehouse.com/partsearch/axle_repair_bearing.html?005=45659879650&007=Search&gclid=CPSI_MCh-8kCFckYHwodmmICbw
http://antakesuma.xyz/fds/b/boss-hoss-bhc-3-ls2-2008-custom-cruiser-v8-automatic-repair-manual.pdf
Boss Hoss Cycles Contact Us
Aug 10, 2009 | Boss Hoss BHC-3 ZZ4 Motorcycles
Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
Dec 29, 2007 | Hoover AL130 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
