Question about Goldstar DH504EL Dehumidifier
The unit kicks on and off about every 3 minutes no matter what settingit is on
    Sergeant:
  • 235 Answers
Sounds like you either have dirty filter, a dirty coil, or a low charge. Can you look at your filters and see if they need to be washed out? Let me know what you find.
Posted on Sep 28, 2010
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
From a cold start, the dehumidifier starts and the fan kicks on. But after running for 2-3 minutes it shuts off. If you remove bucket and reinstall the fan will come on for a short period and shut off...
Wayne, There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit
(no LED screen) set the humidity extraction knob on maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 12, 2011 | Whirlpool AD50USS Dehumidifier
It runs 5 to 10 minutes, then it stops. When I press the remote control boton, it works again for 5 to 10 minutes and then it stops. So I need to repress the remote control again to make it starts.
I guess you are having a problem. That model dehumidifier doesn't have a remote control. As a matter of fact, I'm not aware of any model dehumidifier that has a remote control. A remote would be useless. Now, some portable air conditioners have remote controls. Is that what you have? A portable A/C unit? Please advise. Thanks.
May 26, 2011 | Danby DDR2509EE Dehumidifier
It continues to shut down after start saying it is full, but it has no water in it. No matter if I take out the bucket and push back in it still says full. Not even a year old!!!
Here's a solution that often works. Turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and set your control as you normally do. Hopefully, that 12-15 minute timeout allowed the unit to reset itself. If it continues to do this contact Haier Customer Support 877-337-3639 and have your Model Number and Proof of Purchase handy. If it's less than a year old, it's still under warranty.
Good lick. I hope this helps solve your problem.
Apr 18, 2011 | Haier DE65EJ Dehumidifier
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Kenmore 54701 Dehumidifier
I'm working on mine right now as we speak with the same problem , it runs for 3-4 minutes and then drops out and what I think I have found is the compressor comes on but the fan that blows over the condensor/evaporator assemblies never turns on ! I tore the covers of mine and put a volt meter across the orange and black wires (with the unit on high ) , on the little white plug in the metal box on a pc board , that all the wires go into and with the comressor off just before it starts on power up I have 122vac (volts ac) and then the compressor kicks in and it drops to about 107 vac but no fan action so I'm getting on line to order a motor assembly Kenmore # 4681A20040K ! I just happened across this site so I hope It works for me and helps you !
Jun 30, 2008 | Kenmore 54701 Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Goldstar DH504EL Dehumidifier Logo
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
