Question about Whirlpool Ovens
Have a whirlpool gold black oven and nothing works on the electronic oven control panel but the burners on top work. what could be the problem? thanks, dan
  • 205 Answers
Hello Dan. You most likely need a new EOC (oven control) / clock. These are often expensive but fairly easy to change. If you do decide to try to replace it BE SURE that it is unplugged or the breaker is off. Usually if you pull the range out from the wall (be careful of scratching your floors, put cardboard under the front legs) you can access the EOC from the back of the control panel. There should be a cover over the back of the control with a lot of screws, remove as many as you need to have access to the EOC. It should be evident how to remove the EOC once you see it, often just 4 screws. Have the new one on hand and just be careful when removing wires and make a little diagram if you need to help you remember where they go on the new unit. One thing to consider once you get the cost of the EOC/Clock take a look at the cost of a new range. Sometimes these parts are half the cost of a new range. Hope this helps, best regards.
Posted on Sep 28, 2010
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
What is wrong with my Whirlpool Double Wall Oven-Mod RBD305PDB8? Control Panel is blank. Light & timer works. Nothing else. Breaker ok.
This is a symptom of a common control board failure. Although your board has been discontinued by Whirlpool, your original EOC electronic oven control can be rebuilt. See here for details:
http://www.fixyourboard.com/boards/8302319.html
or here:
http://www.fixyourboard.com/boards/4451991.html
Sep 01, 2015 | Whirlpool Ovens
Whirlpool electric range super capacity 465 RF 377PXGQ0 SER# RH 4718582 the stove burners work nothing else works the control panel and oven are not working at all no lights at all... everything...
Ok
you must have a problem with you neutral leg .
Check to mak sure all 3 wires from power cord are securely connected to machine. Next make sure recepticle at the wall
has a good neutral. Use volt meter to check your recepticle.
You should get 110 volts between any top and the bottom slot.
No 110 volts means check house wiring or recepticle
Yes 110 volts means problem with neutral wiring in machine.(Not likely)
good luck
Jul 26, 2011 | Ovens
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
I have a whirlpool gold self-cleaning oven accubake system super capacity 465. The oven will not get worm. The burners work just fine. The oven runs thought it pre heat time but never gets worm.
While I can't solve your problem, I can say, you are not alone. I own this oven and have been having major issues with it, I have had service men out to my house 3 times and still it isn't fixed. We were told that this particular oven is an experimental unit...it only has 4 working parts. The pilot/ignitor for the burners AND unit are the same, so if burners work it has nothing to do with your pilot light or ignitor. More than likely it is the thermostat OR the motherboard. Thankfully we have home owners insurance and have only had to pay $60 to get them to come and fix it. If you are not so lucky you may just want to call Whirlpool, give them a piece of your mind and then go buy a different brand oven.
Jan 15, 2011 | Ovens
I have a frigidaire m/n PLES389ECD and the burners and oven aren't working and had the error code f20, the clock timer was replaced but now the clock is the only thing working the burners and oven still...
The ESEC system and the electronic oven control ain't communicating. Check the wiring connections between the oven control and the esec controls. The thang is designed to lockout the top burners while the self clean feature is in use. If you failed to reconnect that connection which feeds back to the ESEC I imagine nothing does work. LOL. here's a video which shows how it works and I have the manual loaded on Gdocs fo you.
30 Inch Freestanding Electric Ranges_Rev A (5995438461).pdf (4 megs) printable.
Dec 31, 2010 | Frigidaire Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Ovens Logo
78 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
