Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
No water entering
Lights go on and looks like it's working, but no water enters
  • 38 Answers
Check to see that the water is turned on to dishwasher. If so then your fill valve is likely not working. To confirm check to see if you are getting 120v ac to the fill valve with a multimeter with the dishwasher trying to fill. If voltage is present then the fill valve is bad.
Posted on Feb 23, 2009
HF Error Code on Whirlpool Washer. I am very handy. Have already checked hoses, pressure, etc. Have already unplugged for 2 minutes to reset, etc. Is there a dirty sensor, etc that I should look for?
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Aug 24, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Water in my spare tire compartment
Bummer. Look for water entering at tail lights. Some models have a redesigned trunk gasket that solves the issue.
Look for dislodged sunroof drain hoses.
May 28, 2011 | 2007 Pontiac Torrent AWD
Hello I'm looking for advise on my 11 year old dishwasher. It's a kenmore ultra wash model # 15812. The problem is that when you push the wash button nothing happens. The drain funtion still works and all...
Hello there:
To be honest with you i would first try these solutions and see if they work cause a new machine would cost a lot of money.
But if you can fix yours it would cost a lot less so plese try these solutions that i have provided below first ok?
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 30, 2010 | Dishwashers
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Remote Problems
try re entering the codes for the tv look on the internet for the codes you need and find out how to set them into the remote usually you would hold the tv button until the rest of the lights flashed once and then enter the four didget code until you find the correct one, or the remote might have been dropped or water spilled on it
Dec 25, 2009 | DISH Network IR Remote Control
Lamp out light
check to see if water is entering your tailight housing some how,It may be that water or condensation is entering the left or right tail light,which is causing the bell & check your break light bubs
Mar 21, 2009 | 2002 Dodge Ram Maxi
Asko d1876 dishwasher
The F2 lights blink due to a water senser in the compartment where the motors are located. Remove the bottom kick panel and other covers to access this area of the unit. Unplug the unit before working in this area as wires are abundant. Check the pan to see if water is present. Dry out the pan with a towel and then maybe a hairdryer to clear the F2 alarm. The real questions is what caused the water to be there. Start a cycle and watch to see if there are any leaks on the inlet water line. If not, let the unit run and see when water enters the pan. If it enters during the washing cycle, a gasket leak is likely. If it enters during the drain cycle, perhaps a drain hose is leaking.
Feb 05, 2009 | Asko D1876 Dishwasher
No water
HI thanks for your question. i would look at the water valve . located under the dishwasher. remove bottom plate . replace the water valve thanks the appliance doc
Oct 14, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
No water entering dishwasher
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Sep 29, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
157 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
