Question about Intertherm Heating & Cooling
We have an intertherm heating system, its probably 30 or more years old, and we cant see a pilot light, and we havn't been able to light it. the model is mac 1175.
  • 395 Answers
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Posted on Sep 28, 2010
Intertherm Model MGHA-070AAFC-02 pilot wont light
if it dose not stay on then properly the thermocouple needs changing or pilot could need cleaning.
Mar 07, 2018 | Intertherm Heating & Cooling
I have an old Intertherm 911030 (probably from early 1990) that has a pilot. I would like to change it to an electronic ignition. Is this possible?thanks
Hello again Denise Zier,
If you are concerned about cutting fuel costs...
you can buy a lot of fuel for the cost of conversion...
perhaps a new heater would be a wiser choice...(??)
Call the local Lennox York or Rheem folks
(see below for they guys I used)... 1-800-360-1569.
If the pilot is not reliable... a less than $20 thermocouple
may only need to be replaced...
available through, eBay, AMAZON or (best) your local
hardware store... they just pull out... and BECAUSE
LENGHT is important it is best to take the old one
with you
(big caution... do NOT overtighten)...!!
Buy Goodman Heat Pump Geothermal Heat Pumps Goodman Air Conditioner
Nov 14, 2016 | Intertherm Heating & Cooling
Intertherm/nordyne furnace (24 years old)
Shut off power, get a small wrench, remove orifice spuds and clean them with toothpick. Take burners out and clean rust from them. Check and see if you are getting 24 volts to gas valve. If not replace it.
Feb 15, 2014 | Intertherm P3RA-048K Air Conditioner
The wind keeps on blowing out pilot light in the Intertherm Gas Furnace
The wind is probably not the culprit here. You probably have a crack in the heat exchanger, which allows the air from the blower to escape and blow out the pilot light.
Oct 31, 2013 | Intertherm P3RA-048K Air Conditioner
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
How do I light the pilot on my InterTherm MGBB 070 furnace? I have tried holding in the pilot switch but have had no success in getting the pilot lit.
Just to make sure you are trying to light the pilot, from the gas valve follow the small diameter pipe (1/8") to the pilot assembly. Where you should be placing your flame is above that point. Now with the gas valve knob turned to the Pilot marking, depress the know into the gas valve. Light the pilot. Check to see if it is lit and remain holding the knob in for 30 to 45 seconds. If the flame goes out as soon as you let out the knob, you will need to replace the thermocouple.
Oct 11, 2009 | Heating & Cooling
Where is the pilot light on a Intertherm heating and air conditioning system?
There is no pilot light on this unit. It is a package Heat Pump. total electric.
Oct 11, 2009 | Intertherm P3RA-048K Air Conditioner
We have an InterTherm heating system. The bedroom thermostat will not shut down when it reaches tempreature. This system is about 30 years old. Do you believe the problem is the thermostat or at the...
you have a bad thermostat,there must be a 3-5 degree difference between set point temp and actual room temp,is this a boiler or forced air furnace
Nov 16, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
276 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
