I have only unpacked - have not even put the photoconductor in and i live in a country town
Try this (as per Epson Tech Support): To fix the E527 error, close the front panel (cover A) and open the top
cover (cover B). With the photoconductor unit removed (as you have already), the toner
carousel will rotate. It only rotates if cover A is closed all the way.
You can easily rotate the carousel to a position where you can
remove/reinstall a stuck toner cartrdige.
I hope this works for you. Let me know please!
Posted on May 24, 2008
I just changed my toner and after replacing the toner---I got this message. Your guidance was helpful-it solved my problem; I merely removed the cartridge and re-set it and the problem went away. THANK YOU
Posted on May 25, 2009
This is easy. Ring Epson and tell then to send either a replacement or a technician to fix it.
If you ever have a problem with a product straight out of the box, leave it alone to you spoke with the manufacturer. If you mess with it too much, you may invalidate any warranty.
The E527 error relates to the small sensor locates the dev unit home position. Basically the sensor can not see the dev unit and is most likely just out of line. Problem is it's behind the HV power supply board and requires a good amount of dismantling.
Solution: Call Epson to fix it under warranty.
Posted on May 26, 2008
Feb 24, 2010 | Epson Aculaser C1100 Printer
Apr 16, 2008 | Epson Aculaser C1100 Printer
Aug 14, 2007 | Epson Aculaser C1100 Printer
Dec 28, 2009 | Epson ACULASER CX11NF All-In-One Printer
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Jan 17, 2009 | Epson Aculaser C1100 Printer
Oct 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Apr 11, 2008 | Epson Aculaser C1100 Printer
Mar 05, 2008 | Epson Aculaser C1100 Printer
Jun 15, 2007 | Epson Aculaser C1100 Printer
6,421 people viewed this question
epson cx11nf
