Question about AEG Cooktops
I DROPED A TEA TOWELL ON A HOT GLASS TOP IT HAS LEFT MARKS -FIBERS I THINK IT'S NYLON HOW CAN I REMOVE IT
  • 4,066 Answers
One of those razor blade scrapers works good for burnt on stuff on a glass cook top. It should work for what you have. Be sure you do it at a shallow angle so as not to scratch the glass.
Posted on Sep 27, 2010
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
I have a kenmore glass surface cooktop. A plastic grocery bag was put on it while it was still hot. The bag melted a left a mess on the surface. How do I get it off?
It is glass so I would take a widget razor and try to scrape it. Or try to soak it with hot water then try. I have a kenmore top and it is strong
Aug 24, 2014 | Cooktops
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Glass cooktop has cracked in two places
sounds like a stress fracture is your cooktop supported well
Sep 20, 2009 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Left a empty pan on hot burner and glass top turned smokey under glass and left tiny pit marks on surface the color of the top is black
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Amana AKT3650 Electric Cooktop
Gas valve Switch
First i should say it is very dangerous to preform gas appliance service if you are not trained. if you have evin the slightest question in your own abilities ALWAYS call in the pro's. However I think I can help. 1st turn off and disconnect gas. remove cook top from counter and lay on towel top down. Sense this is glass top there is no service from top. there are a series of screws that go around the perimeter of bottom. remove these screws. The bottom should lift away. this will allow you to change components. hope this helps and good luck.
May 07, 2009 | GE 30 in. JGP336 Gas Cooktop
Igniter
I should say that it very dangerous to service glass appliances if you are not trained. If you have any question of your abilities stop here and call the pro's. Although I think I can help. 1st turn off the glass and disconnect it from valve. 2nd unplug 110v plug. Remove the cook top from counter and lay it top down on a towel. There is a series of screws around the perimeter of bottom. Remove these screws. The bottom should lift away allowing full access to all components. hope this helps and good luck.
Stainless Steel Cover for Grill
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Jun 24, 2008 | Thermador PCS484GGUS Gas Cooktop
Cooktops Logo
97 people viewed this question
Top AEG Cooktops Experts
Charles T Nevin
Charles T Nevin
 Andrew Henderson
Andrew Henderson
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
