Question about KitchenAid Dishwashers
I have a Kitchenaid KUDK03CTSS2. It goes about half way through the entire cycle, let's say half hour in and then it sits there buzzing/droning for at least 30-40 minutes, then it finishes fine. Had a service guy in and he would't wait for the symptoms to appear. Everything is good at the beginning. He replaced the pump motor, didn't find any debris in the unit. But it's still doing the same thing.
  • jbergh Sep 28, 2010
    Ok, checked the unit like you said, there was no water in it and little heat during this droning/buzzing phase. Ran a rinse cycle, I suppose that's cold? Was fine, a bit of buzzing when it drained. Certainly not like the other. My gut is telling me the brain is messed up on this thing and it gets stuck in a mode for a long period for no apparent reason.
  • jbergh Oct 05, 2010
    Ok, got the new vent and seal. Installed it. Found the innerdoor screws mostly loose, tightened. Ran the unit. Buzzing marginally better. Opened the door midway through this and noticed the soap pack laying melted in the bottom of the tub. Cancelled cycle. Pulled off toe cover and restarted. Noticed a white wire with a red stripe laying under the motor. Has a heat shrink on it but looks like it broke off of something.
  • KitchenAid Master
  • 3,247 Answers
Turn the dishwasher off about 20 minutes after it starts the droning/ buzzing and feel the water temperature.
Also run the dishwasher in a short cycle where it uses cold water only and see if there is any difference.
Please post a comment to confirm your observations. This will help me understand the problem better in order to give you some solutions.
Posted on Sep 27, 2010
  • Sam Sep 28, 2010
    I am trying to locate a user manual for you model to reconfirm, but from what you have observed it appears the droning buzzing is coming from the dryer vent. It might be having some problem. The reason you find no water after 20 minutes is that the dishwasher has actually completed the wash/ rinse program and is waiting on the dryer to finish off. Do you find the dishes are dry and clean at the end? The air vent solenoid should open during the dry cycle. see item 5 on page 3 in this list. The actual part would look like this.
    At this stage I don't believe the controller has got any problem.
    Hope this helps locate the offending part.
  • Sam Oct 06, 2010
    Sorry to hear the wire has come off. Most likely it has come off the harness (see item 12 on page 3). Might have been tugged from the other end of the connector when you were working on the vent assembly. Unfortunately I do not have a wiring diagram for your dishwasher. But most likely it might be the detergent dispenser latch wire.
    Check the back of the detergent dispenser (item 8 to see if the connector is missing). The dispenser door would have opened and dropped the detergent (soap) on the bottom of the dishwasher.
    I am afraid this will need a bit of tracking back on which connector pin from the control unit it came off. (item 8 on page 2).
Kitchenaid kawe767wwho repair
you must have something stuck in your pump this will cause your problem the drives brake when the pump freezes up
Sep 27, 2012 | KitchenAid KAWS700L Top Load Washer
How to replace timer on KAWS850LQ0
The buzzing occurs, I turn the washer off, leave it alone for an hour or so, then I come back and begin the wash cycle from the beginning and sometimes it will totally complete the cycle. A couple of times it has just stop at the rinse cycle again. Then I try this same process over again.
Thanks for any help you can provide.
Increase Engine Horse Power.
Jun 02, 2012 | KitchenAid Washing Machines
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
heatman101
Apr 23, 2011 | KitchenAid Dishwashers
Dishwasher model kudk03ctss2. ser # fw0511242.
May I get somemore info so I may help you more
Dec 04, 2010 | KitchenAid Dishwashers
Am getting electrical feedback (droning sound) when I plug in my 2 year old soundsticks. Got any hints?
Check the grounding on the power supply. That eliminates almost all "droning" and "buzzing" feebacks. Try detaching all externally powered accessories to see whether one might be responsible (external hard drives are traditionally the worst, but I got a USB hub once which had a faulty wiring - the droning was the first warning of impending doom).
If this does not work, you can sometimes get rid of some interferences (but usually at higher frequencies than dronings - anyway, it's worth a try) by clamping a ferrite load around the mains wire and/or the DC output wire. Many USB and audio cables will have clip-on ferrite loads which you can unlatch using a thumbnail or a pencil knife, and reuse for your own.
If it's the AC adapter, you might be able to secure a compatible AC adapter that will buzz less. I've found some recovered printer AC supplies from Hewlett Packard to be quite silent electrically (check voltage, wattage and polarity carefully though).
Oct 30, 2009 | Harman Kardon SoundSticks II Computer...
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
Won't Stop
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is
cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher.
Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature
of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than
120 degrees Fahrenheit.
Aug 03, 2008 | Neff 24 in. S5456 Built-in Dishwasher
HELP!
yes the bearings are pressed in. have to find a press
Jul 29, 2008 | 2003 Mitsubishi Lancer
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
Dishwashers Logo
214 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
