Verticle yellow or green line appears in the center of the screen on my hp pavilion. how can i eliminate this line?
  • 3,247 Answers
It could be due to a few reasons.
Does it make any difference to the lines or their location if you firmly press the edge of the LCD frame?
In order to eliminate the source re-install the video driver first.
You will get this from the hp support website. I do not know the exact model no. of your hp pavillion laptop.
If reload of driver makes no difference then it could be linked to the lcd screen or the video card.
It would help if you can connect a standalone VGA monitor to your laptop. Switch to this using the appropriate Function key Fn on your laptop keyboard. If the line appears in the VGA monitor then the video hardware on laptop is a problem. If it does not appear then either the memory module or the LCD screen has a problem.
This will mean a repair bill.
Hope this helps.
Posted on Sep 28, 2010
My laptop is suffering alot .the first problem is that when it shut down it restart again with out my knowledge and as aresult the battary run out of power . as time went i began to experince ayellow...
The Hp pavilion dv6 laptops overheat from my understanding and experience. My sister had one and the same thing has happened. I opened it up and did a reflow, which is pretty much fixing the connections. This is a very hard process. This laptop's gpu likes to over heat pretty much. You should either try to have a professional fix it or just back up your files and sell it.
Mar 01, 2011 | Heating & Cooling
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
May 17, 2010 | HP Pavilion dv6000z Notebook
I have two verticle lines- one white and other one
The screen will likly need to be replaced. Try an external monitor on it, does it still have lines? if not then its the screen on laptop.
Feb 25, 2010 | HP Pavilion zd8000 Notebook
My hp pavillion dv90000 has gray verticle lines and it makes the screen behind really hard to see. What can I do?
In most cases with these lcds...when you see verticle lines and white outs, the most likely cause for this is a screen failure. Your lcd panel is failing and will fail, they are not servicable. First though check the data cable on the left side of the panel, it is secured in the back of the panel and it has been known to come loose from the socket annd this will cause visual problems of many different levels, but that is about it other than changing the screen out. These screen are relatively easy to change out and can be bought on Ebay for as low as 50 bucks.
Jan 06, 2010 | HP Pavilion dv9000z Notebook
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
Dec 16, 2009 | Televison & Video
Hp pavilion zv 6000 no keyboard or screen
Please have a look at this article by clicking here
You may need to update the BIOS
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 20, 2009 | HP Pavilion ZV6000 Laptop
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Laptop lcd screen
that's not a firmware issue..your lcd is starting a slow decay to final unhappiness..
you can try the old driver downloader trick, but it's just a matter of time now.
Feb 21, 2008 | LG Flatron L1750S 17" LCD Monitor
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
