Question about Jenn-Air Kitchen Ranges
My electric range started beeping, the display started flashing F-2, and the Fan does not work. The rest of the cooktop does work....haven't tried the oven...but, we turned it off until we can determine what is wrong. Would appreciate your advise.
  • Jenn-Air Master
  • 1,711 Answers
F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness.
Posted on Oct 02, 2010
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Kenmoe Electric Cooktop and started beeping and fan is running
A F1 code is a bad ERC electronic range control.(clock).
The ERC must be replaced.
Mar 18, 2010 | Kenmore Kitchen Ranges
''Cavity Size 30'' message appeared, can't get rid, can't use oven
Had the same message on my display after spilling water on the cooktop. Obviously, the seal (rubber gasket) that prevents liquids getting inside the control area is not very good.
I replaced the Control (p/n: 10181439 / 9761799, 2 numbers, same part) and the flat cable between the touch keypad and the Control (9762781).
After turning the breaker back on, only had the message to set the clock.
Feb 23, 2009 | KitchenAid KERS807SSS Electric Kitchen...
JENN-AIR MODEL D156B Electric oven
Hi Sadirrd
Your problem (flashing F3) is most likely a defective temperature sensor.It may also be due to a open in the wiring harness connected to the sensor - unlikely but could be.
Post a rating for this solution
Regards
Nov 07, 2008 | Cooktops
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
KITCHENAID KESS908SPW ELECTRIC RANGE
are you sure the oven doesnt need 2 voltage supplies?control voltage and load voltage.
Aug 12, 2007 | KitchenAid KESS908SPB / KESS908SPW...
Kitchen Ranges Logo
174 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
