Question about Pool & Spa
The motor is not producing any heat. The light switched off and wont turn back on. Any ideas?
  • 44 Answers
Call an Electrician. Or better yet a Pool repairman who knows electrical.
Posted on Sep 28, 2010
Does the total power dissipated on the circuit increase, decrease, or temains the same when the switch is close.
In any circuit, when the switch completes the circuit power will be dissipated in the form of work or heat. Work is the energy used to perform a function, such as turning a motor. Heat is energy lost due to circuit resistance, and the power used to create it.
Think of an incandescent light bulb. When the switch is turned on, the bulb uses energy to create light by passing current through a high resistance wire, heating it up. Here some of the energy produced is lost as heat from the light bulb itself.
Mar 31, 2015 | Cars & Trucks
My furnace wont lite
Problem: Your furnace will not ignite the gas to produce heat for your home.The following is the sequence of operation and probable cause:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch (or circuit breaker ) back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands (use gloves). If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 29, 2010 | Heating & Cooling
Have a ruud achiever 90 plus furnace. the flame goes out after the igniter quits. any ideas
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 26, 2010 | Ruud UBHC Air Conditioner
Induction fan motor cycles on and off , with no call for heat
Nov 26, 2010 | Heating & Cooling
Wont Run unless hold start switch
You most likely have a faulty motor centrifugal switch. This switch is engaged when the motor starts rotating. The switch itself could be faulty or the inertia-mechanism that activates the switch could be faulty. The inertia-mechanism usually has two small springs that pull it back into its resting position when the motor stops turning. I have found that the springs will sometimes break and produce the symptom you have described.
Below is a diagram of common centrifugal switches. The switch will be mounted on the end of the motor.
Jun 21, 2010 | Kenmore 63932 Electric Dryer
Dryer wont start
most of these dryers have a thermal fuse that shuts the dryer down when it over heats and it is not resetable. most of these on a kenmore are on the back of the dryer. locate the thermal fuse and use an ohm meter to tell if it has continuity or not. no continuity - replace it.
also if your dryer is over heating one of the most common causes is a crimped vent hose or pipe. don't use plastic hose as it crimps shut easily and won't let the heat out of the dryer causing the problem you described.
May 25, 2010 | Kenmore 500 6952 Dryer
I used the self cleaning function and now the over wont work. The lights work, but no heat is produced. I get no error messages, any ideas?
might want to check if element has continuity with light-wire-battery technique or VOM (volt ohm meter)...unplugged and element out... then while element is out can plug back in and use VOM to check element receptacle for 220v AC (to see if power coming to element (good to check also since continuity check can be fooled by a break in the nichrome wire within the element where the ends of the break only retract to make a gap when main current is applied)
........If no voltage at recepticle then between their and control switch/temperature selector.
...the full blast current and heat of self cleaning, could have completed the ready to fail point/switch/etc
Aug 09, 2009 | Whirlpool RBS305PR Electric Single Oven
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
