Question about Brown Stove Works TM110-3 Gas Kitchen Range
How do i convert stove from nat to lp stove i have is a brown modle number wtm110 3 it is set for nat now
2 Suggested Answers
  • 494 Answers
SOURCE: Brown TM210-4 kitchen range... how
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Posted on Oct 09, 2010
I will soon need to convert a 1993(?) CALORIC Kitchen Range back to Natural Gas from LP. When I installed it, NG was not available, so the propane company guys converted it to LP. I was not here to learn...
First check the regulator valve on the back of the stove. Chances are it is a dual purpose valve and once you are ready to do the converstion.. you simply will move the lever or change the setting from LP to NAT.(obvisouly before proceeding you need to have the fuel supply turned off to the appliance)
Next check under the range lid or on the back of the stove for the spare NATural gas orifices.. when they changed it out for you there were two scenarios.. the range (most do) came with a set of LP orifices..and they simply changed these out on each burner supply including brolier/oven. (orifices are interchangeable nozzles that are threaded into the supply gas burner)
If they had to swap out the regulator chances are they would have given you the one that came with your stove.. However I am fairly sure the regulator is a dual purpose and you simply need to change the setting from LP to NAT.
DO NOT DO THIS WITHOUT CHANGING OUT THE ORIFICES FIRST.
If you cannot locate the spare orifices/spud/nozzles (they are called all of these) on the stove itself you will need to buy a set. A good appliance parts store will be able to help you with these.. again.. you will need one for each burner/burner supply.
If you can locate the range manual it will have instructions on how to do this.
Chances are your Natural Gas company will be able to help you with this.. especially if the regulator is dual purpose.. even if you can't find the orifices they are inexpensive.. fairly standard and easy to acquire. Usually just called a "conversion kit".. it will just consist of four or five small threaded 5/16 brass nozzles/orifices.
The installation is pretty straightforward. Again..a good appliance parts store may recommend a service company...and if your not familiar with diy repairs on a gas appliance.. a 50 to 100 dollar service call is well worth the money.
Best of luck to you!
Apr 11, 2011 | Ovens
Want to convert from natural gas to lp propane
A conversion usually consist of new burner(s)/nozzle(s)/orrifice(s) and either a new regulator/gas valve..
Some gas cook stoves or ranges come with the ability to run on either fuel and the spare nozzle or orrifice will be attached somewhere on the stove.. usually under the range top.. the gas valve may have a small lever that you simply move to the preferred fuel setting.. NAT or LP.
The appliance must have a rating plate that states it can be converted.. and if so..typically a conversion kit will be available or may have been included in the appliance package.
LP Gas runs at a higher pressure.. making a broad statement here.. converting from Natural to LP is more dangerous if the proper steps are not followed then converting from LP to Natural.. which typically just results in a weak flame.. regardless. it's still dangerous.
Many modern appliances will have a warning label stating it can only be used with a certain type of fuel. Heed the warning.
If your appliance did not ship with the alternate fuel kit or has a warning label.. do not attempt to convert it.. it will be much safer and cheaper to buy the proper appliance.
Best of luck.. and be careful
Mar 29, 2011 | Heating & Cooling
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
Oct 09, 2010 | Brown Stove Works TM210 Gas Kitchen Range
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
What i need to do to convert my viking stove mod. vgsc3064b from natural gas to propane? or were can find the serial number on it?. thanks
Crank down and flip.
Tighten all spuds open all shutters and flip the nut on the regulator from NAT to LP. Directions are HERE
Jan 28, 2010 | Viking VGSC306-4B Gas Kitchen Range
Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Jul 23, 2009 | Kitchen Ranges
Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Dec 22, 2008 | Heating & Cooling
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Sf114pxsw1 lp conversion
On the regulator of the stove there is a knot tha you swich to propane it have the latters lp or nat.swich it to Lp. you most open the air vents on all the burners.
Nov 21, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Brown Stove Works TM110-3 Gas Kitchen Range Logo
32 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
