Question about RTO Keys Health Trainer 502t Treadmill
I have a Treadmill Health Trainer HT402. Everytime I turn it on there's a beep sound and monitor showing Err01 and when I pull out the emergency magnet, monitor shows Err07. Treadmill not working right now, someone please help! I just bought it 2 weeks ago ( used).
  • 103 Answers
SOURCE: My Proform 8.5 personal fitness trainer will no longer work
Hello there, It seems that you have a stuck button or a problem with the ifit card area. Yes I know you probably dont use it but just listen. If you have the demo card for the unit try putting the demo card into the ifit slot and press it in and out a couple of times. This will sometimes correct this problem. If that does not correct it then you will need to replace the console or possibly disconnect the ifit section from the console itself. Either way you will need to remove the console.
If more info is needed please leave me a note here and I will get back to you asap.
Good Luck! Tim
Posted on Jan 11, 2010
Testimonial: "Tim, Thank you very much for your help. I already had the console apart so I just unplugged the ifit section and it works perfect. Randy"
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
Error 7 is a Safety Key Error..
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
Posted on Apr 20, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 246 Answers
SOURCE: WE have just moved home and lost our safety magnet
here's a link to an ebay page of treadmill safety keys for horizon treadmills. hope this helps!
Posted on Feb 18, 2010
2manyhobbies
  • 128 Answers
SOURCE: Health Trainer 2.0 treadmill stopped.
The walking belt is moving slower that the console is showing. Many times, the same symptoms can cause an E11 and an E22 error.
  1. The most common problem is belt/deck friction. If you have a belt that has too much friction, it can cause a wide enough speed variation to create an error. You can try our World Famous lube to help but eventually at least the belt will have to be replaced.
  2. Before doing anything, check the drive system for a foreign object. A little "helper" can put a small ball in the drive system and you'll get an error code.
  3. Be aware of any noises the treadmill was making. If the treadmill had a screeching noise, the bearings in one of the bearings or motor could have had a problem. Read our help section on how to find bearing noise to isolate which part is causing the trouble.
  4. Make sure the motor fan is firmly attached to the motor shaft. There are a series of "fins" on the fan that are read by the speed sensor. If it is not properly attached, you can get a bad reading. Also if some of the fins have broken off, a bad reading results.
Check the wire from the speed sensor and make sure it is firmly in place on the sensor and the electronics. Make sure the S F/B LED on the controller flashes as the fan turns. This is telling you the sensor is reading properly. Clean the sensor with a Q-tip and rubbing alcohol if it doesn't flash and if that doesn't fix it, replace the sensor.
Posted on Dec 15, 2010
NordicTrack x9i Terrible banging sound coming from belt roller in back
Try to lubricate the treadmill running belt.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Treadmill walking belt lubrication
Jan 02, 2017 | Nordic Track Exercise & Fitness
Runs a few minutes and then shuts down and beeps
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Feb 17, 2016 | Landice L7 LTd Pro Sports Trainer...
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
Er07 appears on screen on the health trainer treadmill. Remedy?
Error Er07 is usually caused by a bad button on the console of the treadmill. Go to this site to get help to resolve the problem.
https://www.iconservice.com/
Jan 07, 2015 | Exercise & Fitness
How do I center the Keys Fitness Health Trainer 502T treadbelt? thank you.
there are two bolts at the end of the treadmill.one on each side. usually an allen head. tighen clockwise the side that the belt is closest to about a full turn. turn on treadmill about 2mph. watch belt run. it will take 20 seconds to adjust. with unit running adjust till centered.only go 1/4 to1/2 turn at a time and let it adjust
Oct 16, 2014 | Exercise & Fitness
When running get error message your pressing on the board too hard?
RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
God bless you
Nov 13, 2013 | Life Fitness Lifefitness 9100 Hr Treadmill...
Treadmill
see the video and proceed according+ rollers bearing too
However if the problem persist, time to REPLACE the old deck belt board.
God bless you
Jan 14, 2013 | RTO Health Trainer HT-720T Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
My treadmill healthtrainer 720t marks error 11. How can i fix it
This is made by keys fitness. Its a worn belt/deck error. Recalibrate and replace treadbelt
May 29, 2012 | RTO Health Trainer HT-720T Treadmill
Lost key, How can i get anotha1?
This says that the you have is a Health Trainer this was a one of many brands under keys fitness which is no longer in business, but Treadmill Doctor purchased all remaining parts from Keys their website is:
www.treadmilldoctor.com
Apr 17, 2010 | RTO Health Trainer HT-720T Treadmill
RTO Keys Health Trainer 502t Treadmill Logo
159 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
