Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
Water pressure has diminished in my Kohler kitchen faucet but the rest of the house is fine.
  • 68 Answers
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Posted on Dec 31, 2008
  • 68 Answers
SOURCE: kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Posted on Mar 15, 2009
  • 21 Answers
SOURCE: kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
Posted on Nov 16, 2009
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
  • 5603 Answers
SOURCE: Kohler Fairfax kitchen faucet has
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Posted on Dec 29, 2010
No hot water on New Kohler touch less kitchen faucet. Had plenty with old faucet I'm replacing.
You need to make sure that the small flex line going to the water supply is not kinked than if that dont work make sure theres no trash in the cartridge
Oct 05, 2016 | Kohler Plumbing
How can i disassemble the sprayer handle on my kohler a112.18.1m kitchen faucet
1-800-4KOHLER
http://www.us.kohler.com/us/static/helpTopicsHelper.jsp?helpId=728
Aug 27, 2012 | Kohler Plumbing
Irregular water pressure from kitchen faucet, single handle pull out sprayer. What could be the cause and how do I fix it?
Do you have similar problems anywhere in your house,dose this occur when another water source is turned on,if not then a small pressure tank can be installed to regulate and stabilize the water flow at faucet,if you need further assistance re-post giving more detail about exactly what is accruing.
Jun 14, 2011 | Kohler Plumbing
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
Low water pressure while the rest of the faucets
lume build up. pull handle out and unscrew there should be filter inside take out and soak in a cup of lime away overnite rinse well and reinstall
Dec 17, 2009 | Delta Faucet Delta 474 Waterfall Single...
Kohler forte single control kitchen, low colder water pressure
Nov 16, 2009 | Kohler Forte Single-Control Remote Valve...
I have a pfister 536-e series Pfister/catalina colletion kitchen faucet. Low water pressure from both the hot and cold water. How do I fix the water pressure? Water pressure in the rest of the house is...
First unscrew areator from faucet spout, you might need pliers for this. Make sure the areator is clean, sometimes sedement from water lines can slow water down.
Sep 27, 2009 | Plumbing
Kitchen faucet
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
62 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
