Question about JVC AV-48WP30 48" Rear Projection Television
48wp30 ? How do i get to the service screen onb my remote?
I cant find the service screen on my remote. I just replaced my ic's and the red is still there! DAMN! i hope my soldering is ok>? Will a cold solder joint do it? i mean does the solder actually have to run down the wire into the hole? Now what. im lost...pleeeze help me someone
joey h
  • joeyh May 24, 2008
    yes but i thought you could do more with the remote and the service/technitian screen menu. i thought you hold down sleep and v status but that doesnt work. I wish i could get the # of the resistor i have to change but cant get any info on that. The ics are changed, red is still way out. i heard there was a resistor too but dont know witch one (sob)
    joey h (canada)
  • JVC Master
  • 8,617 Answers
Do you have the proceedure to adjust the convergence with the remote and the convergence menu?
Posted on May 24, 2008
  • Sonny Berry
    Sonny Berry May 24, 2008
    that model usually blows the 1.5ohm 1 watt resistor. You can access the service menu by pressing sleep timer then while it still says 0 presss display and V status down together and you will access the service menu. But on your model if you remove the speaker grille and access panel you will see the convergence board right there on the right side. right next to the ic heatsink you will see a real tiny push button. Press that button and that will bring up the convergence grids so you can adjust each color.
IC's for JVC AV-48WP30
you need to get the exact ICS that came out of the tv. you do need a qualified tv technician to solve these problems
Nov 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 Convergence Problem
If you know how to solder, I would suggest to just replace the STK ICs and some of the low value resistors. If you do not how to solder replacing the entire board is the way to to get the TV fix. You might still need to adjust the convergence after the board replacement.
Let me know if you need further assistance.
Jul 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Please help me fix my tv
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
http://servicemanuals.vstore.ca/
Apr 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 convergence problem
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Mar 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Which IC should I replace if the RED is off?
You would need the service manual to dtermine which IC controls the red. One IC controls red and the other controls blue. If the red was replaced before. It probaly went out as some suppliers dont use origional sanyo ICs. Which unfortunately dont last as long as the sanyo parts do.
Mar 13, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Convergence Problems
If you did not use heat sink compound then you probably have not hurt the new IC's yet but you should remove them and add the heat sink compound NOW. If the convergence IC's are bad then you will have access to the convergence menu but the adjustments will have no effect. The fact that you switched the IC's and got the same results shows that the IC's are good. If your red convergence is still way out when the new IC's are installed then the old IC probably burned out the low value resistor associated with the Red Vertical (RV) channel.
Jul 02, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
48 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
