Question about Roper RES7646KQ Electric Dryer
Blows hot air but does not spin. I have the top. back and front off and do see where a belt would go or even the motor. any ideas. Thanks Ron
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 28, 2010
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
The Dryer blows hot air perfectly but the drum is not spinning and produce a metal clicking sound.
Hi Ariel
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Bud
Mar 22, 2013 | Kenmore Dryers
Air blows hot but drum is not turning. belt still attached, can turn it manually. does the motor have a reset? All wires are connected. How do I tell if the motor is dead?
It sounds like you have some experience, which is good. Take the front of the dryer off and remove the belt from the motor and idler pulley. See if u can spin the motor shaft. Chances are it is tight and or stuck completely. You should be able to spin the motor shaft with ease and it keep spinning for a few seconds. If it gives you any sort of resistance, it is dead. It looks like the part number for that motor is 8182471. Unfortunately, it is expensive. The motor will cost around $250. Let me know if I can be of any further assistance.
May 29, 2010 | Whirlpool LEW0050P Electric Dryer
I have a whirlpool lgr5620kq1, the dryer comes on and gets hot but the drum does not spin. Any ideas, also if it is the belt where is the belt located?
remove the front and top and you can access the belt,if not the belt it could be the motor or the motor start capacitor
Aug 24, 2009 | Dryers
Roper rex6634pq0 won't start, buzzes, gets hot on surface
Solution #1 makes no sense as a dryer does not have a water pump!
But the exact same problem happened to my same model dryer. Pull out from wall. Remove lint filter. Take out two screws holding top to lint filter casing. Pry up top at the front (pops out of two plastic retaining dowels and is hinged on the back so you can tip the top up). Remove front panel by taking out two screw-bolts at top of backside of front panel and lift up -- careful to support drum as you do, as the front part of the drum is supported by the flange built into the front panel. Check:
1) Is belt broken (the incredibly skinny belt that runs around the middle of the drum, not the rubber track at the back of the drum). If belt is broke, replace. New belt at internet parts stores is about $10 bucks.
2) If belt is not broke, get down on belly with flashlight and find the spring-loaded wheel that keeps the belt snug against the motor pulley -- push on the spring-loaded wheel and slip the belt off.
Now try to spin the motor pulley by hand. If it turns freely in both directions, it is probably good and the problem might be in the start switch (don't know how to test that).
If the motor pulley does NOT turn -- or is very hard to turn and binds -- the motor is dead. Probably the bearings burnt out (that's what happened to mine after only 4 years of light use). You have to remove the back panel to replace the motor, but it's a simple job if you know what a screwdriver and socket ratchet are for. New motor at internet parts stores is about $80 bucks.
Aug 18, 2009 | Roper RES7648E Dryer
2000 Odyssey A/C in back but not in front.
My name is Ron,I will try and help,You will have a temp door actuator motor that has gone bad,You will have to locate it by process of elimination.Any questions ...roniecon@gmail.com
Jul 19, 2009 | 2002 Honda Odyssey
A/C problems
your a/c should not blow cold air-- is the switched turned on inside your truck - yes there needs to be a belt and it a round compressor with a clutch on the front of it - located on the front top side of your motor
Jul 02, 2009 | 2006 Chevrolet Silverado 1500 2WD
Top rear vents blow out cold air[ 2005 cadillac srx ]
Hello according the the manual, the back vent are to blew cold air only..the fronts vents are suppose to the entire car...
Feb 01, 2009 | 2005 Cadillac SRX
The drum of my Kenmore 80 series electric dryer is not turning
sounds like you need a new drum belt. start by taking the top off then the front panel will have screws inside for removing the front. then once the front is off you will see the motor and where the belt should be. if the belt is broken, replace it, if not just put it back on the motor and idler pulley.
Dec 28, 2008 | Kenmore 659 Electric Dryer
Replacing belt on GE front loader wsxh208a1ww
Ron, be sure the wheel the belt goes around is not loose. The belt will come off if it is loose.
Jan 09, 2008 | GE WSXH208A Front Load Washer
Roper RES7646KQ Electric Dryer Logo
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
