I need a replacement. where can I order one?
  • Dan Copeland Sep 27, 2010
    Ok, You need to supply I Little bit more info on your problem. You cant just say I need a replacement and the wizards here will conjure up a solution for you. You Need to post as much information as you know. What kind of a/c is it? Is it central air or a window unit. What brand is it. What size is it? Model and serial numbers can help out. Gather as much info as you can and we here can help you out as best as we can.
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to givea specific make and model of your unit.
Also include as much as possible about what you have already tried to do toresolve the problem along with exactly what is not working or what the unit isnot doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the firsttime, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 27, 2010
I want to order a replacement driver side mirror for my vehicle. which model do i need?
You need to order an exact replacement for your 2005 Dodge Durango SLT, specifying color and specifying any special features such as an embedded turn signal repeater.
Feb 18, 2016 | 2005 Dodge Durango SLT
What part do i need to order to replace the cracked screen on my philips television model# 42pfl7403d/f7. what part do i need to order, so i can fix it?
Hi Misty,
The broken screen in your TV is replaced as complete panel unit. Usually the replacement is expansive and the panels are not easily available. Better go for new set and put the internal parts of the broken set for sale on internet.
Jan 13, 2016 | Philips Televison & Video
Need screw
You need the thread pitch, and diameter to order one from somewhere, but a local hardware store should have some inventory of left hand nuts and bolts that are at least a grade 5 or 7 (8.8 is a metric/ISO rating and about comparable to a grade 3)
Otherwise with the complete model number you should be able to order a replacement from Sears, Or if Home Depot has a comparable saw (they should) they should be able to order a replacement for you if they cannot find a suitable replacement in their nuts and bolts they stock.
Jun 10, 2012 | Saws
Fixing Order Mix Up on 03 Pontiac Grand Am... I accidentally mixed up two wires when replacing spark plug wires on my Pontiac Grand Am. I have the correct firing order now, but how do I go about fixing...
By mixing the plugwires up all you did was mess up the firing order. If you have the correct firing order, just plug the appropriate wire to the appropriate spark plug. You do not need to unhook the Battery. Unhooking the battery resets your computer and you do not need to do that for this problem.
Nov 08, 2011 | Cars & Trucks
I need to know the firing order to replace wires
No, if you replace one wire at a time then you do not need the firing order. If you have already removed all the wires, then post which engine you have and I will post the firing order.
May 01, 2011 | 1997 Buick Skylark
Code F- Won't spin
Hi, it means you have an internal short in the display control board. You'll need to order and replace the relay control board in order to correct the issue. This control board is located on the far right corner under the control panel. Below is a link to the control board you'll need to order and replace. Click HERE.....
Mar 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Firing order diagram for ford f150 I need to see
FIRING ORDERS NOTE: To avoid confusion, replace spark plug wires one at a time. Fig. 1: 5.8L engine Firing order: 1-3-7-2-6-5-4-8 Distributor rotation: Counterclockwise 88282g01.gif
Fig. 2: 4.9L engineFiring order: 1-5-3-6-2-4Distributor rotation: Clockwise 88282g02.gif
Fig. 3: 5.0L and 7.5L enginesFiring order: 1-5-4-2-6-3-7-8Distributor rotation: Counterclockwise 88282g03.gif
Fig. 4: 6.9L and 7.3L Diesel enginesInjection order: 1-2-7-3-4-5-6-8 88282g04.gif
Sep 09, 2010 | 1994 Ford F150 Styleside Supercab
I broke the 6 cup carafe and need a replacement for my Betty Crocker 6 cup coffee maker
The model number is BC-1721 and you can order a replacement carafe for 12.99 CDN + 5.95 S&H by sending a cheque or money
order to E.F. Appliances Canada Ltd. 9033 Leslie Street, Unit #1,
Richmond Hill, ONTARIO L4B 4K3 (allow 3-6 weeks for delivery).
This info from the little booklet that comes with the coffee maker.
Has an replacement parts order form. They do not take phone orders.
Feb 17, 2010 | Betty Crocker Coffee Makers & Espresso...
What order to replace the spark plug wires
If the original wires are on the car still then replace them according to size and do them one at a time. If you took them off prior to changing them then you need the firing order in which they go
May 03, 2009 | 1989 Ford Tempo
Timing belt replacement diagram
need timing order for dodge ram 2003 v8 4.7 not firing order but timing order
Apr 14, 2009 | Dodge Ram 50 Cars & Trucks
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
