Question about Kenwood VR-616 Receiver
Receiver makes clicking sound before power shuts off. i checked all speaker connections for shorts per troubleshooting!
  • 4,234 Answers
What you are hearing is the speaker protection relays. See the link below for a generic explanation of protect mode (the mode your unit is in at the moment.) Update this if you have some test gear and wish to attempt to repair this.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Sep 27, 2010
Before my Onkyo receiver ht-r591 keeps clicking on/off rightnow is dead , won't power on at all ...Please Help!!!
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com.
Oct 29, 2015 | Onkyo Audio Players & Recorders
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
My Receiver very rarely comes on but shuts off in few minutes even the standby doesn't lit up. but when on works perfectly.
Hi Joseph,
Jun 28, 2015 | Onkyo TX-DS989 Receiver
Keeps shutting off automatically and flashes Protect before it shuts down ??
FIRST DISS-CONNECT POWER FROM RECEIVER.... DO NOT ATTEMPT ANY SERVICE / TROUBLESHOOTING PROCEDURES TO ELECTRICAL DEVICES PRIOR TO REMOVING ELECTRICAL POWER SOURCE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now that the power cord is unplugged we can start. We shall start this repair by doing the easiest tests/checks first. That DOES NOT MEAN that just because the test is easy, its not very important.... every recommendation to follow is JUST as important as the next! (even if what is asked to be checked sounds un-important... its not! Follow this advice and YOU WILL RESOLVE YOUR ISSUE! TRUST ME... YOU WILL FIX THIS issue & before the days over.... SMILE & BE HAPPY! OK...... lets get started) First lets Check the power cord... unpluged? Sure hope so! Now the first thing that you have to do is check ALL the speaker connections at both ends!!!!!!!! (@ speaker & Receiver) Be certain ALL connections are tight & that NO strands of wire are shorting out the connections by touching each other...... the ends of ALL speaker wires must be seperate from each other at all times!!!! Each wire must ONLY be connected to one post/connector!!!!! Only ONE speaker should be connected to each terminal.... do not connect additional speakers to connections at any time!!!!!!!!!!! ONLY ONE can be applied to EACH OUTPUT TERMINAL!!!!!! If the speakers your using are fuse protected check fuses or circuit breakers accordingly. One open circuit (unconnected output terminal) or shorted (wires touching together) will immediatelly trigger receiver to SHUT DOWN!!!!!!! Receiver MUST have a load (speaker) connected to each speaker output to operate properly. Should all wires be found connected properly after checking at both speaker terminals & receiver terminals & problem is still accuring after reapplying power....... additional resistance checks must be made using an OHM Meter (available at most harware stores). If one of the speakers being used has burned out / gone bad / broke...... the only way to determine this condition is via a resistance measurment. Disconnect the speaker wire from the back of each speaker prior to doing resistance check!!! (a false reading will be observed if the speaker wire is still connected during this test) Now touch each of the two speaker terminals with one of the meter leads (the meter must be set to OHMS or RESISTANCE during this test for proper reading). The resistance reading observed should be NO LESS THAN 3 OHMS & NO MORE THAN 10 OHMS !!!!!!!!! Should the resistance/ohm's value of any speaker being used / connected to the receiver be found by the OHM Meter to read LESS than 3 OHMS = speaker shorted... MUST be replaced! Should the resistance/ohm's value of any speaker being used / connected to the receiver be found by the OHM Meter to read MORE than 10 OHMS = speaker open.... Must be replaced! Connecting damaged speakers to any receiver for a prolonged period of time WILL DAMAGE RECEIVER!!!!!!! Speaker resistance MUST be between 3 & 10 ohms to avoid damage to output transistors in receiver.... when receiver senses less than a resistance of 3 or more of a resistance than 10 @ ANY speaker terminal during operation................. IMMEDIATE AUTOMATIC SHUTDOWN OF RECEIVER WILL OCCURE!!!!!!! You've got a bad speaker or a loose speaker wire or a shorted speaker wire...... check each of your speaker connections/terminals & you'll find your problem! When you do find a loose or shorted wire associated with the speakers......... you'll have found your problem! Trust me.... you CAN do it!!!! and when you do... you will SMILE !!!!!!!! & be HAPPY!!!!!!!
GOOD LUCK!!!!!!!
May 14, 2011 | Audio Players & Recorders
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
On/standby Red light blinking can't turn on system
It's in protection. Disconnect all your speaker wires at the receiver then power it up. If it stays on, the receiver is ok and you need to check all wires and speakers for shorts. The easiest way is to reconnect one speaker at a time and test power until it shuts down, then disconnect the speaker wire at the speaker and test again. If it stays on, meter the speaker for shorts or bad voice coil. if it still shuts off, check your wire or replace. If the receiver's power still flashes with all speakers disconnected, it needs service or replaced. Before reconnecting your receiver after repair or replacement, check all wires and speakers 90% of the time, that's the cause. Hope this helps. If you still need help, post a comment and I can help you troubleshoot further.
Oct 17, 2009 | Denon AVR-2807 Receiver
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
Won't Power On...
Hello degaff, This is what I would do to try to determine the problem: 1. Disconnect everything from the receiver. The only thing connected should be the power cord. Make sure the power cord is disconnected from power for at least 30 minutes in order to reset the internal electronic software. 2. Then, power it up - still nothing else connected. If it powers up normally and "looks" like it is going to work, then turn it off and connect only the right speaker to its amplifier and try again. If it still looks normal, then turn it off and connect the DVD or CD player and run some music through that speaker. If it still looks normal, then shut it off and connect the left speaker, etc... In other words go one-by-one in checking it out. 3. If it does NOT power up after step ONE, then there is a problem internally. If it powers up only to shut down again, there is still a hardware problem internally. The usual cause is shorted output transistors. And the normal cause of shorted outputs is a short on the speaker line, a short inside one of the speakers or overdriving the amplifier for too long a period of time. If the outputs need replaced, then it will cost an arm and a leg to get them repaired, and you are better off replacing the unit. The clicking sound, by the way, is the power relay which turns the power transformer on. And if there are faults in the amp, speakers or wiring, the protection circuit shuts the relay off; that is the clicking sound you hear. Please let us know how this works, and if we can help you any further. Best regards, nightdiver
Aug 23, 2006 | Aiwa AV-D57 Receiver
Shutting down
Try first to disconnect all your speakers and see if the sdame thing happens. if it dosent, turn off and start to connect up one speaker at a time. BUT always turn off unit while connecting speakers. Keep connecting till you get to the one that makes the system shut down. Then check the wires for splices cuts or shorts and make sure the ends where they connect to the speaker and reciver isent shorted. if it doesnt work with all the speakers disconnected theres a short in the unit and if its new take it back. Good Luck
Aug 16, 2006 | Onkyo TX-SR503 Receiver
199 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
