Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Aug 2004 UL/FDA MODEL D52W20B. I was watching it and there was a loud crack or pop and TV went out for good. I smelled something burning from the rear of the TV. I have not been able to turn it on since. Any suggestions?
this is me
  • 48 Answers
SOURCE: Pop and burning smell now no picture
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Jan 04, 2006
judesoul
  • 127 Answers
SOURCE: HELP!! zenith r57w46
go to the nearest PC repair shop..your board/processor burned out.
or if you have still a warranty for the laptop better contact the  supplier were you bought it and as for a replacement.
Posted on Oct 29, 2007
Shuttle83
  • 1139 Answers
SOURCE: RCA D52W14
Hello bassin365,
The loud pop you heard was a filter capacitor. The problem now is the power supply is shot, or should I say the capacitor that is connected to that voltage output is blown. You will have to replace it with a new one. I would suggest just for your curiosity, unplug the TV, take the lower panel off (you will need a star head driver to do this) and look at the power supply board (the board on you left side) look towards the middle of the board and you will see a heat sink in the middle of that heat sink you should see a capacitor (or the remains of one). its value is 2200uf 16V (I believe that this is the one that has gone bad), you should also look for others that may have blown also. I would also suggest that you have a qualified TV repair person come to your place and work on this for you, due to the nature of this section of your TV.
If you choose to do this yourself you will find this useful.  Get a schematic to find the values the Chassis number I believe is ITC222. Here is a link to the schematic:
http://www.eserviceinfo.com/downloadsm/3692/Thomson_ITC222.html
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 26, 2008
  • 185 Answers
SOURCE: RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Posted on Nov 11, 2008
protvrepair
  • 153 Answers
SOURCE: Watching the TV heard a loud pop picture went
The first and most likely cause is that your lamp has blown. Simply remove it and inspect when they have blown its really easy to tell. Remove lamp door with a philips screw driver. The door is located I believe on the back of the set towards the right side. Once the lamp door is off there will be 1 maybe 2 screws holding the lamp assembly itself in place. Remove those then the housing should slide right out. The lamp number is 915B403001 for that model.. Good Luck!!!
Posted on Dec 03, 2010
Testimonial: "Thank you so much!"
How do I adjust the vertical hole on an RCA HDTV/ MONITOR Model number D52W20 Serial number D493C304Q Manufactured date Dec 2003.... UL/FDA MODEL D52W20B
The model number does not match the set in the video, this is a newer LCD or Plasma set-almost no set made in the last 20 years has a vertical hold, besides I see 3 images or its 3d and camera saw that.
12_16_2012_3_44_02_am.jpgThis is what the model made in 2003 looks like.
The other set likely has a bad main board that controls everything, without the correct model I cannot even research it.
Dec 16, 2012 | Televison & Video
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
TV made a loud crack or pop and the screen went black
Well if it is DLP TV then crack/ pop sound was broken lamp in TV and if its another kind of TV as you did not mention its model and brand then have to check accordingly.
Nov 10, 2009 | Audio Players & Recorders
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Moved ge hdtv mod#D52GW12 in rainy weather
Sounds like it could be a problem with high voltage stages. Definitely a job for a TV technician as it is dangerous try to repair it yourself.
Oct 31, 2008 | Televison & Video
Sony KP-41S3U
Good Day;
On that model look for a small yellow cap, half the size of coin, dime. LOOK very closely and you will see a small burnt spot on the cap. The TV uses about 4 of them, they are 120/110 @ 2 kv. There are located in the high voltage circuit.
This the most common, it could be flyback or HV devider.
Good Luck and Day, big irish.
LET ME know.
Jun 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv popped and shut off
Burnt small 2KV capacitor near flyback xformer....original is
221K....I use 271K / 2KV ...Possible burnt 1K 1/2 watt resistor
and shorted zener diode ....ECG 519..................T.
Dec 08, 2007 | Zenith B27A11Z 27" TV
Oct 29, 2007 | Zenith R57W46 57" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
