Question about Verizon Communications Samsung Alias Cell Phone - Black
Cannot pair samsung alias phone to motorola bluetooth
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR Sep 27, 2010
    Which model is the bluetooth device you want to pair your phone to?
  • 358 Answers
Hi,it's very easy to pair.
First get one of the phones blue tooth on, and pair with the other phone .
When pairing,it will ask you for password key, you can use any number of your choice, but it has to be a four digit number.(Any four digit number) eg 1234,1111,0000 etc.
Ones you type in the code you want to use for pairing, it wlll ask you on the other phone you are trying to pair to type in that the same code and your done with pairing you, Ones the other phone recognizing the phone you paired it with you can now send data to each other.
If it does not pair immediately, restart the phone and try again.
Good luck.
Posted on Sep 27, 2010
2 Suggested Answers
  • 638 Answers
SOURCE: Have new Samsung Alias 2 that won't pair to my
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
Have new Samsung Alias 2 that won't pair to my motorola car bluetooth, motorola bluetooth ear piece nor newer jabra car bluetooth. Did pair to Magellan GPS bluetooth, but voice transmission garbled. Any...
Oct 05, 2009 | Verizon Communications Samsung Alias Cell...
Jawbone bluetooth won't pair with phone.
sometimes the phone will not pick up on certain bluetooth headsets so i recommend a Motorola.
Apr 28, 2009 | Samsung SPH-m520 Cell Phone
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Jun 21, 2008 | Motorola Mobility H300 Wireless Headset
PAIRED MOTOROLA BLUETOOTH WITH SAMSUNG
hold down the connect button on the bluetooth tl the light stays on, then open the boom, release the button. The light should stay on now, and your phone should be able to find you bluetooth.
Jun 18, 2008 | Motorola Mobility HS850 Consumer Headset
How to pair a Motorola D200 to a phone??
You will never be able to pair the d200 to a phone or another device, for this is a a2dp bluetooth dongle, that´s why it works with your headphones.
Mar 07, 2008 | Motorola Lands Phones
Verizon Communications Samsung Alias Cell Phone - Black Logo
184 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
