Question about Kenmore 24642 Top Load Washer
I have a kenmore 11023812100. no spin. bypassed lid switch and still no spin. does this model have any belts that could be loose? thanks, Gordon
  • Kenmore Master
  • 3,740 Answers
Hi Gordon and welcome to FixYa I am Kelly. Your washer is direct drive for both agitation and spin. There is a centrifugal clutch for spin. If the motor is running and the unit is pumping out water then the clutch lining has failed.
See Item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200/P0111056/00005?blt=06&prst=&shdMod=
It can also be the motor coupling.
See this link under it pumps but doesn't spin:
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
The video is a how to replace the clutch lining.
Thanks for choosing FixYa.
Kelly
Posted on Sep 27, 2010
I have a kenmore 23812100 top load washer that fills up, but stops prior to the draining stage for spin cycle. It just stops after the soaking cycle when its supposed to drain out to rinse. What could be...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part. See the Sears parts list with prices.
Jan 04, 2011 | Washing Machines
Washer will not aggitate, spin or drain cann't find a belt
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 14, 2010 | Kenmore 24902 Top Load Washer
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Dec 03, 2010 | Washing Machines
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
When i close the led hard it works why?
Assuming that the machine will neither wash nor drain/spin unless you "slam" the lid, the problem points to a loose / damaged Lid Switch.
Oct 12, 2010 | Kenmore 15864/15862 Top Load Washer
My chlothes washer won't spin and won't drain the water out of it. How do I know if the belt is bad or not? And if my belt is good how does it go on?
Based on the Stock Number(s) that you posted your question under, this assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine. It doesn't use a belt.
Aug 13, 2010 | Kenmore 15864/15862 Top Load Washer
HOW DO I BYPASS KENMORE SERIES 80 LID SWITCH ON THE WASHER. IT WILL NOT SPIN , BSD LID SWITCH.
Jun 07, 2010 | Kenmore 22942 Top Load Washer
I have a kenmore washer it won't go into a spin the washer is fullwith water and clothes can i jump it into a spin thanks
Apr 12, 2010 | Kenmore 22622 Top Load Washer
Our washer won't agitate nor will it spin properly what's the problem I have a kenmore washer and it is doing the same thing. How do you get the front off of the washer?
Dear Customer
please perform the following checks
Please rate this,Thank u
Dec 17, 2008 | Kenmore Elite 21086
Washer won't spin
The washing machine has a safety feature for the spin cycle. It has a lid switch that will only allow it to spin if the lid is closed. The switch is most likely broken. Very commen. If I can get the model # I can tell you how to bypass it or replace the lid switch. Thanks
Dec 15, 2008 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore 24642 Top Load Washer Logo
355 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
