I print to a printer connected to the company network. I started to print a 40-page document, but realized immediately that the document needed one more change, so i cancelled the print job. After making the change and printing the document again, i walked to the printer and found the printer printing many pages with unrecognizable characters. What might be worng? please help!!
  • 126 Answers
The data send from printer was quered up in the machine memory and was corrupted. reset the print jobs from both the computer and copier. off the machine and on it again to reset the machine memory.
Posted on Oct 01, 2010
Network printer if print test page printing normaly if print pdf or word not printing !!
The test page comes from the printer itself. If the printer is on a network you need to re-establish it on the network using its IP address. If it is a network printer on one computer, you need to redownload the software.
You should also go to Settings/Printers and make sure the machine itself is the default printer rather than some type of Windows virtual printer like 'Print to File' or 'Print to PDF', Print to Fax' or a printer that is no longer there.
Nov 18, 2015 | Office Equipment & Supplies
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
Copying a 40 page documente front to back, the printer stopped, said memory was full and it said do not cancel but the printing never finshed. There was also another option but I cannot remember what it...
Well sometimes you can restart the printer...also you can start printing where it left off if you see what page it was and then hit print and look in window and set start page such as 21-40
Nov 03, 2010 | Lanier Office Equipment & Supplies
How to reset th eprinter?
Take out the power cable from the printer and then keep the power button pressed for 30 seconds. After that connect the power cable and try to print.
May 26, 2010 | Lexmark T640N Networkable Mono Laser...
Started printing 20-30 pages of article, realized not enough paper in printer, but not being my machine didnt know where to find more paper, for some minutes now machine wont print at all
You have to go to Control Panel or TaskBar where you can see your PRINTERS folder. If ther are many printers listed, select your printer.
You have to delete the printing job from the queue.
When there is nothing more in the queue,
Print again, this time go through the menu, and instead printing the whole article specify pages like Pages 22- 40 ( Omit the first pages you have already printed.
Hope this will work for you, have a good day
luciana44
Sep 22, 2009 | Epson Office Equipment & Supplies
Printer keeps on feeding paper and prints illegible material -- if I turn off and on again it will continue feeding same --- how can I correct this problem which has occurred before and stops and resumes...
I assume you use windows XP and have you printer connected to you computer directly.
First turn off the printer, then go in your printers manager and pause the printer you have problem with it.
Delete all documents still in the printers queue. When deleted, put back on the printer, unpause the printer and print a test page (with the printer's property page on, you should have a test page button), if they dont delete, restart the computer, they shoul not be ther after rebooting.
If the test page goes well, maybe the document is corruped and need some fixing (some big picture do this problem on printers) check with other documents if they print well.
If it goes wrong again, do all the same thing again but beffore reprint, download and install the last version of the driver for you printer/OS.
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
I have an HP Photosmart C7200 All in one printer that is only a year old, and it is just printing out blank pages. It will print any test page from the solution center, so the printer is working just fine;...
It is more likely the program that you are using than the prnter. Open START ACCESSORIES and NOTEPAD place some text on thios page and send to printer If this prints OK then whatever you are using to create the documents that dont print is the offender. If its a mices all thaduct Can I recommend a freebie that does all that MS does and more.
go to www.openoffice.org and download the program. Its a full working and FREE type of MS office without any high price tag. It writes like MSOffice saves files in office foirmat and reads msoffice files It also behaves better in printing. Even the menu and icons are similar
Jul 31, 2009 | Office Equipment & Supplies
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
ML4600 only print 2 pages
It could be losing connection to the printer when there is too much information to print.
If the cable the information needs to travel through is too long or the distance to the printer is too far - information is "lost" due to the stability of the connection.  The longer the information needs to travel the more unreliable and unstable it becomes.
Have you tried from a different computer to print the document?
Nov 29, 2007 | Samsung ML 4600 Laser Printer
307 people viewed this question
k24674
