Question about Genie Aire PACR9 Air Conditioner
Although I set the desired temperature, it only reads that number for a brief minute then it changes to a much highter number. How can I set the thermometer?
    Habit-Forming:
  • 156 Answers
What your seeing is normal. Anytime you change the temperature by pressing the up or down arrow to change the setpoint, it will show you what your current setpoint is. After the keys are idle, basically, your not touching the keypad for 5 to 8 seconds, it changes to the current temperature in the room. So, when you touch the keys, it gives you the temperature you want. When you don't touch the keys, it shows you what the actual temperature is in the room. Your unit is running normal and as designed.
Posted on Sep 28, 2010
What is the ideal setting for fridge on Bosch KGN34VW20G
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
Oct 23, 2014 | Bosch KGN34VW20G White 280 l Fridge...
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
Temperature reverts back to old number which is 33 and is too cold for vegetables. How can I set it to 37 degrees
set the controls to off. then , unplug the unit from the wall for 15 minutes. this will allow the control processor to completely reset itself . after fifteen minutes, plug it in and reset your desired temperatures on your controller. if this does not work, I would suggest you consult the manufacturer or your owner's manual for more information on programming the temperature controller.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How do i set a hunter theromtate #441100. i don't
Set the temp you desire and hit "Hold temp" or "program overide"
Hunter thermostats are notorius for problems.
Whenever I have a customer that is unfortunate enough to be stuck with one I always reccomend they replace it with a "Honeywell" or "White Rodgers" brand T-sat.
What kind of problems you might wonder?
Every kind imaginable.
If yours is not holding the set temp when you tell it to, it's probably not you, 99% chance the thing is simply malfunctioning.
Aug 29, 2009 | Heating & Cooling
Talk about frequency change
To change channel & code press talk and monitor while turning radio on. Radio will speak current channel. Release both talk and monitor. Press talk to change to next channel or press monitor to keep current channel. Press monitor when desired channel is selected, radio will speak current code. Press talk to change to next code or press monitor to keep current code. Press talk to change code as desired then press monitor when done. Will speak channel and code selected. Set all units in same manner to communicate.
Oct 15, 2008 | Motorola Talkabout T5800 (22 Channels)...
Manual or directions
We have the same model. From the manual:
STEP 1: Slide the system switch to the HEAT or COOL position to program the corresponding system
STEP 2: Press PROGRAM to enter program mode. Heat or cool will be displayed on the LCD.
STEP 3: Press the UP or DOWN arrow. The Program hour and AM or PM indicator are flashing. Press to change the hour.
STEP 4: Press PROGRAM to change to the minute position. The current minute will be flashing. Press the UP or DOWN arrow to change the minute.
STEP 5: Press PROGRAM to change to the program temperature. The current temperature will be flashing. Press the UP or DOWN arrow to change the temperature.
STEP 6: Press PROGRAM again to move to the next program number. Repeat Steps 3-5 to change the remaining Weekday and Weekend Programs. [there are a total of 8 programs]
After cycling through all 8 programs, press PROGRAM again to return the display to normal. Press HOLD/RET at any time to exit the Program Mode.
TEMPORARY MANUAL OVERRIDE:
To temporarily change the current set temperature without affecting your program:
  • Press either ARROW and hold for about 1 second to enter the Manual Override Mode. When display flashes, you can release the key.
  • Press the ARROW to change to your desired Temperature
  • Press HOLD/RET to return to normal mode, or wait 15 sections for it to return automatically.
  • The current program number will flash to signify the Temporary Overide.
  • At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature.
Hope this is what you need. God Bless.
Jun 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
partsinfo@dpi-global.com
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Electric stove oven does not obtain proper temperature and does not cycle
This is a very generic question. If it is an old electric range with mechanical controls, the thermostat may not be cycling properly. Most new electric ranges use electronic sensors which send a signal to a board. This signal changes as the temperature changes. Technically, the resistance of the sensor changes with the temperature and that resistance is the input for the circuit board. The circuit board then adjusts the temperature according to the signal it is receiving from the sensor. A good technician should be able to check the resistance in the sensor to see if it is within acceptable range. If the sensor is good, they would be able to troubleshoot the board or other controls.
Nov 01, 2007 | Stoves 1100DFSID Kitchen Range
Genie Aire PACR9 Air Conditioner Logo
174 people viewed this question
Top Genie Aire Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Genie Aire Heating and Cooling Expert? Answer questions, earn points and help others
