Question about Dometic Rooftop RV Air Conditioner
Turned on the ac and heard like a popping sound also a faint smell of smoke
  • Dometic Master
  • 43,501 Answers
The pop was the arcing of electric somewhere in the A/C unit.
Either there is a wire rubbed through, a capacitor blew or a connections somewhere was loose and make sparks...
Open the unit up and you will see the black part that smoked somewhere...then you can figure out if it is fixable or not...
heatman101
Posted on Sep 27, 2010
My AKAI 47' powered off, smoked-smelled, was checked by repair, no problems. Heard 2 pops, unplugged-HELP!
where there is smoke, pops something went---find another shop that knows what they are doing---never plug in a set that smoked!
Aug 27, 2012 | Akai PDP42Z5TA 42 in. Plasma Television
Black smoke from exhaust 2004 accord
Black smoke is burning oil.White smoke is due to water getting in to a cylinder from a bad gasket, cracked block or a cracked head. cracked heads.
Jan 18, 2012 | Honda Accord Cars & Trucks
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
Turned on tv no picture only sound then i heard a pop and smelled burning tv turned itself off. 5 min tried turning on tv again nothing happened tv does not turn on at this time
Your RCA TV needs serious troubleshooting. Burning smell is from HV transformer or resistors smoking.
Most likely power supply and/or high voltage circuit or convergence circuit. Many times RCA have multiple or secondary faults that occur with HV or convergence failure.
Repair of RCA HV or convergence usually requires exact manufacturer parts and upgrades or repair in power supply. I would not advise trying this repair without manufacturer support for correct part numbers and service bulletins.
easyab
Feb 28, 2010 | RCA Televison & Video
Rpm drops while adling causing 'grinding' sound while white smoke flows from behind or below radiator.
You should replace the cooling fan. With the ac on and no cooling fan, high pressure builds in the condensor and compressor bogging the engine down. When it gets too high a relief valve dumps and you get what appears to be white smoke. It's actually freon, hence the smell. I've replaced several PT cooling fans with the same symptoms.
May 16, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Prima l080i
Magic smoke GONE!
Seriously, the main power supply has failed, and requires service. You are probably well past the warranty period, but check with the TV's service center - that information should be in the documents that came with the TV.
Jul 07, 2008 | Prima CV2011 TV
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
