Question about Daewoo DWA-146R Air Conditioner
I have an daewoo wall air conditioner unit that is out of freon or refrigerant,how can i repair the air conditioner and get some cool air outta of the unit
  • Daewoo Master
  • 43,501 Answers
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 27, 2010
Can I add freon to a Goldstar window air conditioner
Hello, Thank You for using FixYa. I will be helping you today. The only time you add freon to an AC unit is if you find a leak and repair it! If its not cooling well you should just clean the front and rear coils.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | LG Goldstar WG6005R Wall/Window Air...
How can I recharge the airconditioner with freon. thank you john
heatman101
Sep 27, 2010 | Daewoo High Energy Efficiency Air...
My air conditioner delivers cold air only in spurts. It then goes into fan mode for a few minutes, then to cold air in a few more minutes. It is over 100 degrees outside and the inside of the house is 85...
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up
The unit will need to be recharged or replaced...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
heatman101
Sep 27, 2010 | Fedders AED24E7F Wall/Window Air...
Add freon to wall unit air conditioner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Heating & Cooling
Return fins on front of unit (behind air fliter) continue to freeze up.
You may need freon, but don't attempt it yourself...
http://www.fixya.com/support/r5638346-add_freon_air_conditioner_or
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | Whirlpool CA24WCR Thru-Wall/Window Air...
There is no cold air from DAEWOO Air conditioner.
this could be a multitude of things: you said it worked when installed,window unit right anything punture the coil exposed to outside, if so freon leak no freon no cool Secondly is the filter dirty these unit needs to breath to work if its dirty it wont cool. switches in the same position turn them back and forth a few times see if that helps. always look for the obvious first and work your way back from there. If this is the first time you ran it since purchase was anything punctured on install if not maybe it was a lemon take it back if possible if not charging these things are a pain, it will need taps on the high and low side this should only be accomplished by a licensed professional and could be costly. give this a try and goodluck
Jul 11, 2010 | Daewoo DWC-056CL Air Conditioner
Window unit not cooling how to put in freon
You have to put a piercing valve on the sucction side because this units don't come with service port, but if you going to add freon ,it is better to fix the leak before and after that replace the drier and vacum the system.
Aug 17, 2009 | Frigidaire FAC124 wall/Window Air...
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
Daewoo DWA-146R Air Conditioner Logo
250 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
