Question about Jazz DV-179 Digital Camera
My sd card is locked how do I unlock it to remove the pictures Thanks
    Genius:
  • 1,340 Answers
Is it new?Usually an SD card comes in the locked position.Remove the card from the camera.There should be a metal tab which slides back and forth.Move it to the other end from the current position.That should be unlock mode.Turn on the camera to check.I don't remember if my LCD said it there or when I took a picture but you will kow immediately either way.Good luck! Greg
Posted on Sep 27, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
How do I unlock my SD card
Jun 03, 2011 | HP Photosmart M22 Digital Camera
When we try to take a picture on our Vivatar Camera it says,card locked. Please help us with this problem.
Most likely your sd card is locked. Try removing the sd card and moving the small white tab on the side of the sd card from locked to unlocked and give it a try.
Lewis
May 15, 2011 | Vivitar ViviCam 5024 Digital Camera
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
Mar 01, 2011 | Cameras
How do i unlock my sd card
The only way to lock / unlock an SD card is with the little switch on the side, it's on the actual physical SD card itself. Take out the card and on it you will see a little switch you can actually "flick" one way or the other, one is locked, and the other is unlocked. It should have a little picture of a lock or the words LOCK on it to indicate which was is which.
Thanks
Tim
Sep 30, 2010 | Motorola Mobility CLIQ Cell Phone
Can't take Picture
Some SD Cards have a physical lock on the side of the Card. Try taking the card out of the camera and look for a small white piece of plastic that you can slide on the side of the card. You may need to slide it to the unlocked position for the camera to be able to write to the card.
Mar 17, 2009 | Polaroid i1035 Digital Camera
Samsung digimax4010 memorycard locked cant take pictures
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 26, 2009 | Samsung Digimax 4010 Digital Camera
Card Locked
If it is an SD memory card, there is a switch actually on the edge of the card. Try moving it to the other position and reinstall. Most people don't realise it's even there untill they have problems.
If this works , please rate accordingly so others may follow.
Thanks.
If it doesn't, there will be access to view the locked photo's on the camera. Selecting protect/ lock again should remove this.
Jul 09, 2008 | Canon PowerShot A550 Digital Camera
Jazz DV-179 Digital Camera Logo
274 people viewed this question
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Corey Fields
Corey Fields
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
