Question about Honeywell CT500 Digital Heat / Cool Manual Thermostat Heater
Hi Where I can buy ct500 honeywell thermostat Thankyou
  • Honeywell Master
  • 3,309 Answers
TRY national energy they are on line
Posted on Sep 28, 2010
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
I have a Honeywell CT500A thermostat. I set it at 68 degrees. the room temperature is 62 degrees. The unit cycles on and the "flame" icon shows on the screen, but then the unit goes off ( the...
Here is a simple way to tell. Remove your thermostat from it's mounting plate, locate the wiring, the red and white are low voltage control wires. Disconnect them from the base and join the two together if the furnace runs you need a thermostat if not it is in the controls to the furnace.
Dec 27, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
I am not sure. I looked on line and saw theHoneywell CT500 Digital Heat / Cool Manual Thermostat. This is the type of thermostat that is on the wall.
Honeywellthermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Dec 15, 2010 | Heating & Cooling
Just installed a honeywell thermostat, but I can't get the clock to set or the temperature to change on it. How do I get the clock to set?
May be your thermosta setting under locked. By seeing your thermostat manual release lock and then you can satrt changing temp setting or clock setting.
Dec 02, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Accidentally programming it
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 07, 2009 | Honeywell CT500 Digital Heat / Cool Manual...
Thermostat no longer showing temperature
Check for lose wires to the thermostat r a blown fuse in the furnace compartment.
Dec 17, 2007 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
