Question about Whirlpool Duet GHW9150P Front Load Washer
My washer will not come on and there is a in "Red" on the panel "Control Locked".
Hold the "end of cycle signal button" down for three to five seconds. Mine has instructions underneath the "end of cycle button", but we didn't see it until after we read the manual. The button is on the far right of the control panel, at the bottom.
Posted on Sep 28, 2010
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    The contol lock red light is lit and I can't get it to work
    Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a control locked alarm on a whirlpool duet washer??
    Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Front loadin washer says control locked!
    The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
    The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
    Please do refer this link for a detailed explanation for your knowledge.
    http://www.fixya.com/support/t4186517-control_lock_light_machine
    Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Whirlpool duet washer and on the control panel the light that says control locked is on and the washer does not work - is there a way to reset it?
    Press the Pause/Cancel button twice then press and hold the End of Cycle Signal button for three seconds until the Control Locked light turns off. If it doesn't work, unplug the washer for at least fifteen minutes to reset it.
    Replace the user interface/LED assembly if the Control Locked indicator still lights up and not allowing you to operate the washer.
    Remove the three screws at the rear of the top panel securing it to the back of the washer. Slide the top panel back and lift it off the washer.
    Disconnect the user interface/ LED assembly ribbon connector from the left side of the central control unit (CCU) and release it from the wiring harness brackets.
    Pull the dispenser drawer out and press down the release tab at the back of the drawer to pull it out completely.
    Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
    Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
    Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
    Gently pry up and release the top of the control panel and pull it off the washer.
    Pull the cycle selector knob off the control panel and release the tabs securing the user interface/LED assembly to the control panel. Lift the user interface/LED assembly from the control panel once all the tabs are released.
    Install the new user interface/LED assembly into the control panel by inserting it into the tabs from one side to the other until it is completely secured.
    Install the control panel on the washer and the top panel in reverse of the removal steps.
    Note: Please specify the model number of your washer for the specific replacement parts.
    Mar 01, 2010 | Dryers
    Disply red light indicates control locked
    The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the washer. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
    If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
    http://www.fixya.com/support/r3608801-control_panel_lock
    These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
    NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
    Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet Washer Control Locked
    I need some more info.. when you say locked up do you have a dispay or is it blank?
    Nov 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    20 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
