Question about Breville SHM2 Stand Mixer
I'm looking for a breville mixer SMH2 manual - Breville SHM2 Stand Mixer
Do you have a lid for a Breville FP2A please ?
No This site is not a parts store
contact the manufacturer spares department and order on
Apr 12, 2015 | Food Processors
Manuals breville
I do not know why you would which to remove the motor. I do not recommend it. The motor is connected to a transmission in the front of the mixer and was most likely pressed in to place by a machine into a baring in the back of the transmission. As far as I can tell the only user serviceable parts are in the back. Primarily the bushings and the back service cover.
To remove the windings you will need a puller. You might be able to find one at your local auto parts store, or one of the stores that specializes in tools such as Harbor Fright, Northern Tool or something like that. Once you remove the back cover you should see the armature, simply attache the puller to the shaft and extract it. If you are lucky you will be able to reinsert it in the opposite order. However, there is a chance that parts of the transmission will fall out of place making it difficult to reassemble.
I am pretty sure you can disassemble it, but putting it back together will be much more challenging.
If you are having trouble with a switch or the bushings I would call Kitchen Aid first. Help Contact Us KitchenAid
Aug 25, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
BEM800 speed going flat out
It is likely that the speed control switch is defective.
Nov 30, 2013 | Breville Food Mixer BEM800
The scraper mixer pro
just google your mixer mod an get manual a recipies
Aug 27, 2012 | Breville The Scraper Mixer - BEM410
Breville mixer
A long screw driver for sure and a magnet
on a stick to pull the screws up.
Once the bottom is off the rest is easy.
Take your time, a lot little things to undo
but easy. Enjoy
The Gears
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-0.jpg Remove and fit the bearing caps one at a time to keep the head in
swing position.
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-3.jpg Use needle nose pliers to remove this plug, just wiggle it out.
Don't pull on the cable
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-6.jpg Opps
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-15.jpg A belt sander works for this.
Apr 03, 2012 | Breville Food Mixers
I was bought it for christmas last year forgot to check it and now find it does not have a manual please can you help
Hi Valerie:
The Instruction Booklet for the Breville SHM2 380 Watts Stand Mixer can be downloaded from the following address:
http://ecx.images-amazon.com/images/I/A1Qx-DxXTMS.pdf
Thank you for using FixYa!
Oct 16, 2011 | Breville SHM2 Stand Mixer
Where can I get replacement Beater Blades for my Breville SHM2 mixer?
Call Breville or look on their website at http://www.breville.com/. If you are in the US, call 1-866-273-8455 for replacement parts.
May 26, 2011 | Breville SHM2 Stand Mixer
Please can u tell me if i can get the blades for this mixer and how much they will cost.
Yes the blades are available as spare parts for the Mixer. I suggest that you contact any nearby dealer of the Mixer.The price depends on the Quality and there are many makes of blades which is compatible with your mixer.
Mar 27, 2011 | Breville SHM2 Stand Mixer
Breville wizz stick professional doesnt operate.
If you can feel anything when you press the button, unplug it and try to turn the mixer. Once you get it freed up, put a drom of cooking oil where the shaft comes out through the case.
Jan 14, 2009 | Food Mixers
Breville SHM2 Stand Mixer Logo
70 people viewed this question
Top Breville Food Mixers Experts
jwinter716
Level 1 Expert
Bill Boyd
Tom Chichester
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
