Question about Kenmore HE2 Plus Front Load Washer
I have a kenmore front load washer and the code f33 comes up and I can do anything. I seems it freezes up. I unplug it for a few minutes and it restarted. But there must be a problem I looked up the code and it said an electrical problem what could it be
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 28, 2010
Kenmore elite he4t f33
The F33 code can indicate a bad pump or a problem with the wiring either at the pump or the CCU (central control unit), or the wiring harness itself. Before you replaced the pump, did you test the resistance in the wiring harness?
Unplug the washer and use an Ohmeter (VOM) to test. See http://media.fotki.com/1_p,wtftddqbdtwbdkrxgtqsskgwtqkq,vi/tgdkbwkswxfddbwsbdbxtbgtgwftb/1/1303472/5961857/image49983img-or.gif for the schematics of the wiring for the pump on the CCU. To access the CCU, you need to remove a few screws on the back of the top panel. You remove the lower service panel on the front of the washer to access the pump. The wiring should read 12.3 ohms at the CCU. If you get a reading of infinity (open), check the pump. If the leads to the pump motor give a resistance of 12.3 ohms, then the wiring harness should probably be replaced. If the circuit to the pump is fine and the error persists, then the CCU is faulty and needs to be replaced.
I hope this helps. If you add a comment with the specific model of your washer, I may be able to give additional suggestions.
Dec 23, 2012 | Kenmore Washing Machines
Tip
Good directions. Thanks. However I tried just unplugging the washer for a few...
This advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code. The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
I hope this information is helpful.
on Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
I have a kenmore HE2 plus with error code F33 and F21. Washer is not fully spinning out and remains full of water at times and other times it does. What are the error codes and can it be fixed. Needs...
CLICK HERE
Thanks for using FixYa&^%%$
Jan 08, 2011 | Kenmore HE2 Plus Front Load Washer
F33 code poped up
CLICK HERE
Thanks for using FixYa#$%$
Jul 14, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore He2plus washer that gives me an error of F33
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jun 19, 2010 | Kenmore HE2 Plus Front Load Washer
Getting a f33 error on front load kenmore HE4t already changed the pressure switch and flow meter but still get f33 error
Jan 22, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My washer said f33 on in. What does this mean?
F-33 Error Code.
When the connection between pump
and the Central Control Unit (CCU) is
lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to
the pump and Central Control Unit
(CCU).
3. Plug in washer or reconnect power.
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
I am receiving error codes on my HE 2 plus front loading washer. F33, F22. and it won't get past the 1st cycle. Is the problem the CUC. or is there a quick fix to this problem.
i found this site thought you may find some help here but there seems to be a lot of peeved off people when it comes to this brand lol
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~6621/forum_id_~409
Jun 13, 2009 | Kenmore HE2 Plus Front Load Washer
F33 error code. drum begins to rotate and then
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
