Question about Soleus Heating & Cooling
I need ablower wheel - Soleus Heating & Cooling
  • Soleus Master
  • 43,501 Answers
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Sep 27, 2010
I got a 1998 Nissan Pathfinder what size wheel spacers do I need to put aftermarket rims on it
1. You don't need wheel spacers for aftermarket wheels for your vehicle. Who told you did? There are a large number of wheels that will fit straight onto the vehicle and will clear the brakes no problem.
2. You will need hub centric rings with many wheels so that the wheel fits flush onto the hub mounting . The wheel dealers will provide you with the correct size hub rings when you purchase the wheels. The hub rings snap into the wheel center and are fitted to the back side of the wheel center.
What is hub centric ring
3. You need to ensure you use a wheel that is a compatible/suitable offset so that the wheel and tire will not sit too far inside the wheel well so you have sufficient inside clearance as well as sufficient clearance for the brakes. In other words suitable clearance inside and outside. If you are looking at certain wheels that will require a wheel spacer to clear your brakes you are looking at the wrong product and an unsuitable fitment for your Nissan.
Nov 03, 2015 | Nissan Cars & Trucks
What course ablow in R2Ks 10 diode in a Panasonic EVO 51 tv?
diodes blow from excessive current draw or reverse polarity.or incorrect voltage
Apr 09, 2015 | Panasonic Televison & Video
Why do I smell dusty air when my heater is on in my 97 silverado ?
Might want to check the a/c filter for the cabin and /or the evaporator under dash
Sep 27, 2014 | Air Conditioning and Heat for Chevrolet...
Remove steering wheel on 85 dodge diplomat
Disconnect the negative battery terminal. Remove the horn pad on the steering wheel-Phillips head screws from the back side of wheel. Then loosen the nut on the steering wheel center. Mark the steering wheel to column shaft position, so the wheel goes back in exact same position on the shaft. You may need a steering wheel puller to get the wheel off the shaft, not always, but sometimes the wheel is on pretty tight. Do not hammer on the wheel to get it off, use a puller if needed. These pullers are at parts stores and not expensive.
Dec 31, 2013 | 1985 Dodge Diplomat
Oil covering air filter
sounds to me it has ablow back. check your pvc valve an the returns in the heads could be stopped up but the pvc could be open an do that hope it helps
Nov 26, 2012 | 2001 Ford Escort ZX2
Continuous horn like noise when engine is off
is it your horn possible problem in steering column if not trace around under the hood to see where noise is coming from could be a relay ablower not shutting off you'll have to look and listen where source for problem is located then act on it or take it to the dealer
Jul 07, 2012 | Cars & Trucks
On the rotor of my 1991 honda there is a bearing
You have to use a slide hammer to get it off
Apr 09, 2010 | 1991 Honda Accord
Economy
Any vehicle that has to drive its own wheels requires horsepower. The more wheels that require power the more energy spent. If you only require 2 wheel drive to get you along that is good. Sometimes 4 wheel drive is needed. 4 wheel drive is needed in drastic situations. Does 2 wheel drive and 4 wheel drive differ? YES The power required to drive 4 wheels is increased 5.7% as to run 2 wheels. 4 wheel drive should be used at slow speed to overcome loss of traction of 2 wheel drive.
I hope this helps Moe
Apr 24, 2009 | 2006 Jeep Grand Cherokee
Tv will not turn on. the standby/timer button blinks
Ablow dryer on the back right corner fixed the problem for me. A humidity sensor was probably dusty or activated
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY TV
No horizontal (Hstop) Check Capacitors C515 and C516 and the Jungle IC What is your model number?
Dec 30, 2007 | Televison & Video
Heating & Cooling Logo
233 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
