Question about NetGear WGR614 Wireless Router
My router will not connect to the internet
If i connect my router to my laptop with the ethernet cable it works fine but as soon as i want to go wireless i cannot connect to the internet. The laptop connects to the router but says locally connected but will be locally and internet connected whent the ethernet cable is in the laptop. What am I doing wrong? I have the same problem when I connect to the router I lose the internet I do not understand the solution it is just a question not what to do to fix the problem. please it is important that I be able to accomplish this.
Thank you and God Bless
tricia
    Brigadier General:
  • 6,966 Answers
A possible reason is that the WiFi is not using the router's IP add as the Default Gateway. To confirm this, pls use static IP add to the WiFi mimicking the settings while in Ethernet except do a +1 on the IP add while retaining same numbers for the Subnet Mask and Default Gateway.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
  • Louie  Role
    Louie Role May 24, 2008
    sorry gentlemen for doubling up. cheers.
  • 667 Answers
Hi tricia. Are you using security for you wireless such as WPA, WEP, etc. If so, you must have the key code from your router entered on your wireless card so it can have access.
Also, you must make sure the Channel and SSID are the same. If not you will get the symptoms you've described.
If this solves you're problem please rate as fixed. If you need help with these settings just add a comment and I'll be more than happy to assist you further. Thanks.
Jeff
    Genius:
  • 2,035 Answers
Please follow these steps:
teps:
1. Connect PC to one of the 4 LAN ports of ur Netgear via LAN cable (DO NOT connect it to ADSL router right now).
2. Change LAN IP address to something other then 192.168.1.x. like suppose 192.168.2.1. To do that click on LAN IP Setup....apply. my router will not connect to the internet - wifi_ip.jpg
4. Right click on the connection icon in sys tray and hit repair.
3. Now connect WiFi router to ADSL modem as earlier.
4. Run WiFi setup Wizard.
This should get you started.
Ok, here are the steps to make the connection secure.
1. Login to the netgear.
2. Go to Advanced>>Wireless
3. Uncheck Enable SSID broadcast. Apply
4. Click on Setup Access List
5. Turn access control on. Add ur wireless cards mac id to the allow list. Apply
Additionally you could do this.
1. Go to Setup>>Wireless Settings. Here notedown the connection name(SSID) since you'll be needing it later.
2. In security options, choose WPA-PSK
3. Put in a passphrase.
4. Put in the key lifetime as 15min. Apply.
Ur net connection will stop working after this coz u have to configure ur laptop.
5. Now if ur using a laptop with intel centrino, then go to Start>>Intel Pro Wireless. If u were using the windows client earlier, switch to this one.
6. Make a new Profile. Put in the connection name (SSID). Click next.
7. In the Network Security option, choose WPA Personal from the menu and TKIP from the Data Encryption Menu. Put in ur passphrase below. Save and click on Connect. U Should be back online now with a secure connection.
Let me know how this goes when you try it and if you have any questions on this, please tell me. thanks.
Att 2wire 486 router, why does ethernet light go off when widows boots on, wireless works fine?
Are you connected by a cable to the desktop, if so try another cable.Is your ethernet adapter enabled and working properly on the desktop?
Oct 12, 2012 | Computers & Internet
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The laptop may not have the correct wireless settings same as the router.
What is the Operating system of your laptop and does it have a builtin card?
May 21, 2008 | NetGear WGR614 Wireless Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Pc works via ethernet cable but wireless laptop cannot see the network
I think you have lost your PPPOE internet connection. Reestablish the connection. If this is not the problem, click your wireless connection on the taskbar and search for your wireless device and reconnect. BPCS
Dec 29, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
106 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
