Question about Breezaire WKL 4000 Wine Cooler
I have the 8000 WKL Breezaire it has started to frost up over and over. I turn it off to melt and it starts to frost as soon as it starts to cool the wine room. Why?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
IF THE BLOWER ON THE COLD SIDE IS NOT RUNNING THAT WOULD BE THE REASON WHY THE COIL FREEZES UP AND IT COULD BE DUE TO A BAD BLOWER CAPACITOR LOCATED ON THE BACK OF THE UNIT LEFT SIDE (SMALLEST OF THE TWO OVAL CANISTERS), BUT IF THE BLOWER IS RUNNING ON THE COLD SIDE IT MOST LIKELYIS A FREON LEAK, AND UNIT NEEDS TO BE RECHARGED WITH FREON AFTER REPAIRING THE LEAK.
Posted on Sep 16, 2011
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
Compressor tries to start but won't ...odd odor when fan runs....approx 8 year old unit... will trip surge protect power strip, but not 20 amp circuit..
IT PROBABLY IS OUT OF FREON AND AS IT TRIES TO START DUE TO THE LACK OF REFRIGERANT AND OIL IN THE LINE IT SHUTS OFF OR IT COULD BE A BAD STARTING DEVICE ON THE COMPRESSOR THAT POPS THE POWER TRIP.
Aug 01, 2011 | Breezaire WKL 4000 Wine Cooler
WK4000 breezaire 60260229 need exhaust fan motor ser.34T U mod.JA2M430N 6CV79C
PART IS SOLD AS TWO SEPARATE COMPONENTS MOTOR AND BLACK PLASTIC BLADE APROX $80 FOR BOTH
Jul 23, 2011 | Breezaire WKL 4000 Wine Cooler
WKE 3000 temperature panel has stopped working - unit still turns on and off properly.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Nov 11, 2010 | Breezaire WKL 4000 Wine Cooler
Unit runs but does not cool.
IF YOU UNIT IS IN FACT A WKL UNIT(DIGITAL DISPLAY) IT COILD BE TWO THING A BAD BOARD THAT IS NOT SENDING POWER TO THE COMPRESSOR OR A FREON LEAK.
ON MAJORITY OF CASES ON A FREON LEAK THE UNIT WILL FORM ICE ON THE COIL, SOME TIMES A LOT OF CONDENSATION ON THE BODY OF THE UNIT AND IT WOULD LOOSE COOLING GRADUALLY UNITIL IT WOULD RUN NON STOP.
CONTAVTTHE MANUFACTURER FOR A BOARD OR ASK FOR A TEMPERATURE DIFERENTIAL TEST TO CHECK FOR A FREON LEAK.
Oct 25, 2010 | Breezaire WKL 4000 Wine Cooler
WKL 3000 is creating excessive condensation and icing on the bottom of the unit. It is about 13 years old.
There will always be condensation. The problem may be that the drain that carries the water off is partially plugged.
Sep 20, 2010 | Breezaire WKL 4000 Wine Cooler
Not cooling... cleaned the rear grill, temp at 80 degrees. when press the thermostat button to lower the temp, nothing happens
IF BUTTONS DONT RESPOND THEN YOU HAVE TO REPLACE THE CONTROL BOARD SENTRY III
CONTACT THE MANUFACTURER TO OBTAIN REPLACEMENT BOARD 858-566-7473
Sep 08, 2010 | Breezaire WKL 4000 Wine Cooler
Temperature controls not working
Your thermostat is bad and needs replacing.
Mar 09, 2009 | Breezaire WKL 4000 Wine Cooler
Breezaire WKL 4000 Wine Cooler Logo
309 people viewed this question
Top Breezaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
