Question about Kenmore Elite 45986 Front Load Washer
F-2 Error Code
What does it mean? It stops mid cycle and I have to unplug it in order to get the machine started again and I keep getting the same code.
  • 1 more comment
  • mrslmz May 24, 2008
    When the machine has a load of clothes in it, the cycle stops and F-02 is displayed. The machine will not drain and spin with an average load of clothes and water in it. However, it will go thorugh the Drain/Spin cycle when there are just a few items or the machine is empty. Initially, we made certain that the hose was not clogged.
  • wallytwin May 28, 2008
    The machine stopped in mid cycle flashing F-02. When I tried to get the machine to go again it would not start and the cancel button would not work either. Eventually F-02 displayed again and the door unlocked. At this point the machine has water in it and will not work.
  • joeybladb Jun 01, 2008
    I've got an F02 code as well, and I can't get it to open -- it's full of water -- it won't even spin or do anything. Just putters around for 5 minutes that starts beeping.
    I checked the drain hose and it's good.
    I googled around a bit and tried out a few things:
    You can remove the bottom front panel very easily (3 screws at the very bottom of the machine). This reveals the drain filter access, which is basically a big white plastic handle which you can turn to unscrew the filter -- the filter is attached to this.
    I grabbed a bunch of towels and a wet-vac, and began to unscrew this thing. Gallons of water poured out all over the place, but I kept at it. Finally all the water was gone, and I checked the filter, but it had no obstructions.
    I noticed that the drain pump motor housing is extremely hot. I suspect IT might be the cause.
    I put the filter back in and started the Drain-Spin cycle. Halfway through, I opened the filter just enough to get a dribble of water out, and wet-vac'd it up. The cycle completed after about 10 minutes, and I drained the filter housing out.
    I don't think the drain pump motor is working! I've removed it, and I'm going to shop around for a replacement.
I replaced the pump motor (http://www.searspartsdirect.com/, #280187) and it works now. The part was back ordered and via express delivery took a total of about 2 weeks.
Posted on Jun 14, 2008
I had a repair man come in and he cleaned the coin trap and pump housing, it had some small rocks and other small items. After cleaning it out it worked well again.
Posted on Jun 03, 2008
  • 240 Answers
F2 is long drain so your already on the right track. check and replace drain pump.
I get the F-21 error code and the washing machine stops mid cycle.
Unplug the plug for 15 seconds plug it back in and try again
Jan 27, 2015 | Washing Machines
What does Code F on washer mean?
Hi. Some of the Error Codes for Cabrio Starts F. So Look at the number coming after F. e.g. F81 -> lid opened.
Here is the a list of Error Codes on some site for troubleshooting.
Troubleshooting Cabrio Bravos Oasis Washer Problems
Aug 01, 2014 | Washing Machines
Our wash machine keeps stopping mid cycle and blinking "Lr". We can start it again but then it stops again when it switches to the next cycle. Sometimes we can't get it to start again, it just sits for...
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
I keep getting a 5d error code on my machine. What is this?
This is actually a SD code meaning to many suds. The machine will drain out mid-cycle when you push stop. You can then start the load over without adding any additional soap. Make sure you use the recommended amount of HE soap.
Mar 02, 2009 | Kenmore HE2 Plus Front Load Washer
Unable to cancel cycle and restart machine
Instead of hitting cancel twice, only press once,. You should hear the washer unlock. Then try to start again. If that doesn't work, try unplugging the washer in mid cycle. Are you getting and codes popping up?
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front load beeped and flashed f with no numbers and stopped mid-cycle. now what. i've pushed red button x2 and tried spin/drain and nothing. now it is stopped again. help!!
In many cases these error codes can be erroneous. If you reset the Central Control Unit (the Main Control for the washer), in many cases, the problem will clear. You must unplug the washer for AT LEAST 30 minutes in order to do this, however. If an error code returns following a CCU reset, then you have a legitimate problem.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
