Question about Samsung Televison & Video
Hooked up a new D.V.D. player now the T.V. will not work says weak signal Entered code for D,V.D. I think
  • bertmaynard Sep 28, 2010
    I hooked up a D.V.D. player to my new 52 inch samsung T.V. now I am getting no picture I followed the instructions to load the new D.V.D. I was getting a message weak signal on the screen now no message I got a message from Silverdragon that you would have to be a technition to understand.also he says press minue that brings up nothing.Could use some simple help Thx Bert
  • Samsung Master
  • 17,130 Answers
Please connect the DVD to another set to confirm if there are errors on the signal if so check the DVD. Now the TV should work on the RF inputs without an issue and if there is an indication it can be that the input connection is faulty or broken resulting in the weak signal indication. So check the connection to which the DVD was given.
Also check the AV channels for fault if so the TV must be taken out to check from the input side
Posted on Sep 28, 2010
  • Samsung Master
  • 12,061 Answers
OK, the DVD must be connected to the set via, the External Audio/Video connectors, and it uses the TV's External Inputs. It does NOT use the "Tuner". One selects the external input from the menu on the TV set.
It can be connected, HDMI, Component, or Composite, all external. Once hooked up and selected correctly, there should be a signal from the DVD displayed, usually there will be a Header image from the DVD displayed onscreen, if connected up all OK.
Posted on Sep 27, 2010
I bought a wireless Linksys wireles- G router used for 5.00. They said that it had a weak signal. I hooked it up and sure enough I have a weak signal. So weak that it does not connect to anything but there...
I made mine into a range expander with this information
http://lifehacker.com/#!5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
If you up to the challenge and can follow instructions, takes about 30 min to do.
When you put on the new OS for the router you can up your signal too.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
Puk code entered, but failed
think aout the day when u put your pin in......just close ur eyes and think of that day.
Feb 22, 2010 | RIM BlackBerry Curve 8310 Smartphone
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Can enter code on keypad to lower garage door, however keypad just "flashes" when code is entered to raise door
If your other remotes are working normally I would suspect first of all a weak battery in the keypad. Secondly the keypad could be getting weak and the closed door blocks enough of the signal to cause your problem. An open door lets the signal through. Normally during the time the keypad is flashing you can hit 'enter' again to reverse the door if it is closing or stop the door if it is opening.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
No antenna signal nor found channels for my area.
You'll need a better antenna to solve your problem. With the new digital broadcasting, signal strength is everything. With analog, a weak signal would give you a watchable but fuzzy picture. A weak signal with digital gives you nothing, or possibly a picture that freezes up or breaks into blocks (pixellation). The only cure is a better antenna, either an amplified indoor antenna or something outside.
Sad to say, there's no guarantee that will work. If you live too far from the station, or have hills, buildings or other obstructions that block the signal, you just may not be able to pick up some channels. In some areas people have found they get no reception at all.
At www.antennaweb.org there's a tool that will tell you what stations are around your area and how far. It's designed to help you figure out what kind of antenna you might need.
Jun 15, 2009 | Insignia IS-PDVD10 Portable DVD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
RCA DTA800B1 converter box - Works great for 15 min. then quits.
I would suggest to return it because it should work as intended without dropping the signal.
It would be a good idea to add a signal booster to keep a good signal strength.
Mar 31, 2017 | Televison & Video
My panasonic CQ-VD7001U won't unlock...
what i have done when i had one was i held the joystick on the player for about 3-5 seconds and then pressed the mode/power on the remote and it reset the player and entered in 0000 for the code and it works. just my personal experience.
Aug 01, 2008 | Panasonic CQ-VD7001U Car DVD Player
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
