Question about Samsung SyncMaster 940MW 19" LCD Monitor
I have a smsung 190s 19" monitor, no power . What am i looking for power supply or black light? My email ruth.stan38@yahoo.com
  • 11,361 Answers
Both.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 28, 2010
How do I tilt my Samsung 190s monitor?
If you mean tilt back/forward, grab the screen with your hands from both sides and tilt the top towards you are away from you.
If you mean rotate to get vertical instead of horizontal orientation, you should look at the back of your monitor to see if it even allows that movement.
Try downloading the User Manual if you don't have one:
http%3A%2F%2Fmypdfmanuals.com%2Fuser-manual%2CSAMSUNG%2CSYNCMASTER%2B190S%2C771044.pdf&ei=fwdgUvSCBoPiyAG_u4HgCg&usg=AFQjCNFYTlCuYjoHd4j7epiG7VRCpSalsw&sig2=iplcvOt8JdNoQqHqbG1g5A
Oct 17, 2013 | Samsung 190S (Silver) 19 in. Flat Panel...
Screen is black with power light on. When I turn the power off and then on the screen comes up for a split second then goes black again.
Look for caps with bulging top in the power supply section first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 08, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
Acer LCD monitor--> screen is black, light is flashing between yellow and green however screen stays black
First thing to look will be bad caps with bulging/leaking caps in the power supply section, post back what you see insdie so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | Acer AL1916W 19" LCD Monitor
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
No display on 190S monitor. It's 3 or 4 years old and has worked great until today. The green power light is on, but no display. I tried rebooting the PC and turning the monitor off and back on. The...
It can be the backlight inverter circuits went out, open it up and look for bad caps with bulging tops first, then look for 12~18vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Samsung 190S (Silver) 19 in. Flat Panel...
My hp w1907 19' monitor goes black light stays green
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Nov 25, 2009 | HP w1907 LCD Monitor
Monitor flicks on but does not stay on
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 28, 2009 | Philips 190S5CB (Black) 19 in. Flat Panel...
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Samsung SyncMaster 940MW 19" LCD Monitor Logo
71 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
