Question about Euro-Pro Fast and Easy 420 Mechanical Sewing Machine
I can't get the bobbing to thread. - Euro-Pro Fast and Easy 420 Mechanical Sewing Machine
  • Euro-Pro Master
  • 7,365 Answers
Check to see if the needle is damaged
check to see if the needle is in backwards
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 28, 2010
Adjust tension
The tension of the top thread and bobbin thread are in a "tug of war". If the top is "winning" or too high then the bottom thread will be showing on the top of the fabric. If the top is "loosing" or too loose then the top thread will be pulled through the fabric and show a lot on the bottom. They must be evened out so the "tug of war" is even so the knot is in the middle of the fabric.
START WITH BOBBIN FIRST: Remove bobbin and bob from finger. When you have it adjusted right then the bobbin will extend one inch when you bob it. If you can't bob your bobbin you will have to make an approximate and replace. You may have to do this a couple times to get it right.
WHEN IT'S RIGHT: The bobbin and top tension are equal without being too much pull on both that causes the fabric to pull together.
Jan 31, 2015 | Sewing Machines
I have a consew 227 without reverse and can't tighten the bobin thread for the life of me. Do you think it might be out of timing? Please help thanks in advance.
THE SPRING THAT TIGHTENS AGAINST THE THREAD IS BENT OUTWARDS. IT MUST BE BENT INWARDS BY KEEPING THE TIP HELD UP WHILE YOU PUSH DOWN ON THE SPRING WITH A SMALL SCREWDRIVER. THIS WILL BEND THE METAL INWARDS. NOW, WHEN YOU TIGHTEN THE SPRING AGAINST THE THREAD IT SHOULD TIGHTEN AND LOOSEN AS YOU ADJUST IT. TO ADJUST YOU JUST NEED TO HANG THE BOBBIN FROM YOUR FINGER AND BOB IT UP AND DOWN. WHEN YOU ADJUST IT PROPERLY THE BOB WILL CAUSE THE THREAD TO EXTEND ONE INCH. THIS HAS NOTHING TO DO WITH TIMING SO DON'T BE CONCERNED ABOUT THIS.
Dec 27, 2014 | Consew Sewing Machines
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Bobbing is getting notted all the time
first you must make sure that the bobbing thread is nicely threaded "no loos or notted thread. What kinda of machine do u have?
the tension on the machine depending the fabric and don't start sewing the piece right at the edge start a lil further and use you back step to assure stich
Oct 23, 2009 | Brother Sewing Machines
Thread keeps knotting up in bobbing casing
Make sure the bobbin is wand correctly. It also need tension. you have a bobbin case be sure it inserted correctly.
Aug 08, 2009 | Sewing Machines
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
Apr 22, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Breaking needles bobbing in huge ball and thread not even
i cleaned and oiled it and it fixed itself.
Nov 15, 2008 | Sewing Machines
Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
