Question about LG BG8000ER Air Conditioner
My lg 15000 er air conditioner is blowing hot air i could hear compressor starting for five minutez of cooling the n shuts off and hot air again i have cleen filtered and cleaned coils inside part
  • LG Master
  • 43,501 Answers
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up and you reset it by turning it off and then on again...
The unit will need to be recharge or replaced...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 27, 2010
Fan runs. Why won't the compressor start?
probably a relay on module either bad or not communicating with thermostat.
Jul 12, 2015 | Coleman 15000 Btu Rv Roof Air Conditioner...
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Air condition unit is not cooling
looked if it works in the outdoor unit if the compressor is not replaced pyknoti.an again does not work then you should buy a new air conditioner.
Apr 20, 2012 | LG Heating & Cooling
Working but not cooling
Check and make sure its on cooling mode and just not "fan only"
You should be able to hear the compressor start up a few seconds after the fan starts. One easy way to tell if an AC is working on cooling is it should be blowing hot air outside and cold air inside. If not, you may have a gas leak or the compressor is not starting..
Jul 14, 2011 | LG Electronic Window Air Conditioner
A C blowin hot air. cecked unit outside. Fan is not blowing. Turned off, allowed to cool off. Unit worked 10 minutes. now blowing hot air again
Sounds like another problem with the capacitor being bad, if you cannot hear the compressor operating either this may be the case.
Jun 25, 2010 | Heating & Cooling
My lg a/c only blows air with no cooling what is
possible a tstat problem or compressor is not coming on...put your ear by the ac unit...if you hear a buzzing noise ,then shuts off,humming...compressor not coming on...
May 09, 2010 | LG LB1200ER Air Conditioner
LG BG8000ER Air Conditioner Logo
194 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
