Question about Samsung RB1955VQ Bottom Freezer Refrigerator
Freeze doesn't freeze and fan in fridge is now making noise
  • Samsung Master
  • 43,501 Answers
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 27, 2010
I have a whirlpool fridge cool keep freezing up causing fan to freeze up makes a lot noise
Sounds like the fridge thermometer is not working and needs to be replaced
Nov 20, 2017 | Whirlpool Refrigerators
Hi I have a samsung fridge freezer. Sl39wj1/xeu. Doesn't seem to be doing anything no light but is continually flashing f5
not sure what you mean water in fridge and ur assuming? did it freeze everything or not freeze? is fan not running or compressor? any noise or sounds?
Mar 14, 2015 | Samsung Refrigerators
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
My freezer doesn't freeze anymore
Could be a bad evaporator fan motor. Is the top part of your fridge warm? Are the sides of your unit hot?
Mar 14, 2013 | Whirlpool Refrigerators
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
My amerian fridge freeze the fridge is frezzing everything
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
My rv ref is freezing top and bottom please help
hello,My fridge is freezing things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
please kindly rate the solution if it's helpful.
take care.
Jun 15, 2010 | Dometic RM2652 Refrigerator
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
We have a Samsung Fridge, Model SRS 598 NSS, side by side fridge and freezer. The fridge started making a loud noise when the door was opened as if the fan was coming to a halt. We had someone come out...
sounds like the motor is bad. if you have a warranty have him change it regardless if he thinks it is bad. the motor should not be noisy. If no warranty then have him check motor very good. also low refrigerant charge as well as it running too long can freeze it up and stop the fan. most refrigerators are designed to be against the wall this can be a factor in a freeze condition. I hope this helps you!
Jun 07, 2009 | Refrigerators
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
188 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
