Have a rmc95c2 need to change the wick - Heating & Cooling
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to give a specific make and model of your unit.
Also include as much as possible about what you have already tried to do to resolve the problem along with exactly what is not working or what the unit is not doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the first time, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 27, 2010
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
I have a hunter air purifier model number 36316 and need to know how to change the filter
Hello, this is Ava with Think Crucial.
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
I need to change the wick on my dyna glo but do not have a manual can you help me?
When you buy the correct wick, the installation instructions will be with the wick. That's especially true, with the Kero World Wicks, brand.
Mar 11, 2011 | Heating & Cooling
Wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Dec 16, 2009 | Heating & Cooling
Have a Dyna-Glo. Took it apart to change the wick
take the wick back out lower your nob and install wick, I hope this help you, I have made this mistake too
Oct 23, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Nov 26, 2008 | Heating & Cooling
Flame is too high after we changed the wick
the wick needs to be reinstalled in the raised position
Nov 16, 2008 | Heating & Cooling
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
