Question about Troy Bilt Tb70ss Gas Trimmer
How can I remove the gas tank - Troy Bilt Tb70ss Gas Trimmer
    Scholar:
  • 71 Answers
Remove the Air Cleaner/ muffler/carburetor plastic guard.
Remove the carburetor (2) bolts.
Remove the Carburetor mount assembly (4) bolts.
The fuel tank is "sandwiched" between the crankcase and the Carburetor mount assembly.
Note: Don't loose the rubber mounting pad....
Posted on Sep 28, 2010
HOW DO I FIX THE CAR AFTER WATER WAS THROWN INTO THE FUEL TANK?
have to remove the gas/water in that is in the tank by removing the tank so you can turn it upside down and make sure every drop of the gas/water is out of the tank siphoning it out may leave some old gas/water in the bottom of tank then get rid of it let the tank dry out for a day and reattach it, then refill your tank with gas it may screw up for a little bit until the gas/water trapped in the fuel line is totally gone.
Go to you tube and look up "removing gas tank"
Dec 12, 2015 | Cars & Trucks
Fuel filter location?
most are in the gas tank.
Easy job if you have a floor jack, 2 floor stands and wrench.
Empty the gas tank, place jack centered on the gas tank jack up the car, put the floor stands in place to hold the car steady, disconnect the wiring go to the gas tank then remove the bolts (most cars only have 2 holding the tank braces, slowly lower the floor jack with the tank on it, remove the fuel pump slowly and carefully as not to have anything fall in the tank.
https://www.youtube.com/results?search_query=remove+gas+tank
Dec 10, 2015 | Cars & Trucks
How do I disconnect gas tank from the line that fills the tank?
How to fix a leaking gas tank - YouTube
? 7:20
www.youtube.com/watch?v=Luj6qPuxIPM
Mar 10, 2013 - Uploaded by FastestIntegra How to clean and fix a leaking gas tank. ... i repair rusted gas tanks with fiberglass putty, works really well, i have a car that i fixed 7 years ago ...
Sep 27, 2015 | Cars & Trucks
How to remove fuel tank
Procedure to remove a fuel tank depends on brand, model and year of the car. Just some examples:
How to properly remove gas tank
How To Remove Gas Tank
How To Remove The Fuel Tank
How to drain your car fuel gas tank
How to drain gas tank on 1984 ford ltd crown victoria to remove the old gas?
If the old gas is bad you should remove the tank, dump the gas, and clean the inside of the tank. You may have to siphon the gas to get to the point where you can manage the tank to remove it.
Jul 30, 2015 | 1984 Ford Bronco
Remove gas tank. Remove sending unit, drain fuel.
Aug 21, 2013 | 1991 Cadillac Eldorado
Need 2 know how 2 remove gas tank so i can replace fuel pump
TO REMOVE FUEL TANK FIRST YOU NEED TO MAKE SURE FUEL SYSTEM BEEN DEPRESSURIZE. YOU CAN REMOVE FUEL PUMP RELAY LET CAR RUN UNTIL DIES LACK OF GAS. THEN CRANK ENGINE OVER FEW TIMES MAKE SURE ALL GAS OUT OF FUEL LINES. THEN REMOVE FUEL CAP THEN DRAIN FUEL TANK.YOU CAN BUY A SIPHON AT ANY AUTO PARTS STORES, DONT SIPHON GAS WITH MOUTH CAN BE VERY FATAL.ONCE FUEL OUT OF TANK. SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS, MAKE SURE VECHICLE SITTING ON LEVEL SOLID GROUND. LOOK UNDERNEATH VECHICLE REMOVE FUEL FILTER DISCONNECT FUEL PUMP ELECTRICAL WIRE CONNECTOR, THEN REMOVE EVAP CANISTER, VENT SOLENOID, AND VAPOR LINES DISCONNECT FUEL LINES, THEN REMOVE THE LOWER FILLERHOSE GOING INTO FUEL TANK. LOOK AROUND TANK YOU PROBABLY HAVE TO REMOVE HEAT SHIELD AROUND GAS TANK AND REMOVE EXHAUST PIPES IF IN THE WAY. GET A LARGE FLOOR JACK AND THE PLACE A PIECE WOOD ON FLOOR JACK SADDLE.THEN RAISE FLOOR JACK JUST ENOUGH SUPPORT FUEL TANK THEN REMOVE FUEL TANK SUPPORT STRAPS THEN SLOWLY LET DOWN THE FUEL TANK. TO FINISH DISCONNECTING FUEL LINES AND REMOVING FUEL PUMP. BE SURE AFTER YOU DEPRESSURIZE FUEL SYSTEM TURN OFF RADIO AND REMOVE THE NEGATIVE BATTERY CABLE.
Aug 04, 2011 | Chevrolet Cavalier Cars & Trucks
Fuel tank removal/fuel pump removal
First, remove the seat and disconnect the battery. Disconnect the hose at the bottom of the gas tank. Place an approved container on the ground and allow the gas to drain out of the tank until empty. Remove the console over the speedometer assembly.Remove the bolts connecting the tank to the frame. Remove the screw in front of the seat, at the back of the Harley-Davidson gas tank. Lift the tank up a little bit and disconnect the wiring harness from the tank. Lift the tank off the frame, taking care not damage the fuel line connections on the tank.
There is no fuel pump on a Harley Fat Boy.
Dec 06, 2009 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Not getting fuel
if you have low fuel in tank . take a large floor jack with a piece of ply board on jack saddle a small piece just enough to keep saddle punction a hole in gas tank.make sure you remove charcoal canister the fuel filter.+ fuel supply and return lines remove the exhaust system.place a large container to catch some gas . remove the tank filler hose. take floor jack place it in center of gas tank slowly raise the jack to support gas tank.remove tank straps slowly lower gas tank catch fuel in the container from the tank filler hose. becareful no sparks what so ever you or a time bomb .
Mar 31, 2009 | 1999 Oldsmobile Alero
Troy Bilt Tb70ss Gas Trimmer Logo
199 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
