Question about Craftsman Garden
I have a model 358797202 gas blower,when i pump bulb dose'nt pump gas will not start replaced fuel lines.
  • 1,041 Answers
Here is a link to a couple of my tips. I think you will find that the Den Tek brush will solve the problem.
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Sep 29, 2010
The little pump for gas does not wok
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Garden
Hi I have a PB1000 echo leaf blower, I have spark and compression,although there is no primer bulb on this model, so the fuel must have to be vacumed with fuel pump. I used the choke and it still...
Try a tiny spray of Starter Fluid in your machine. If it runs for a second then dies,,,, it would indicate that you have a Fuel problem. Broken gas line of gummed carburetor. Ethanol gas is known for ruining both gas lines and carburetors.
Aug 29, 2013 | Garden
Fuel tubing to pump up carb.
-Try to swap to the other one it there are two lines.
Good luck
mai
Dec 06, 2017 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
Have two blowers.....both under two years old...both wont start...kept clean, use proper fuel mixture and all...what gives?
did you drain the fuel out before storing for the winter? this is most common mistake, therefore the fuel gels up in the carb and lines I would ,first does your primer bulb work does it fill with gas? If so pull the air snorkel off so you can get a squirt of carb cleaner in there to see if it will fire up and run, playing with the choke when it does start keeping it running to pull fresh gas into carb, also would'nt hurt to check your fuel filter in tank
Apr 29, 2011 | Echo Gas Blower 204 MPH765 CFM Blower...
Primer bulb does not show gas after 10 to 14 pumps, will not start . Gas line from tank to carb is flowing ok. changed gas, spark plug.
Fuel starvation - 'lean fuel' condition
Remove Carburetor
replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 12, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
80 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
